Firewall Project
Old Sep 14, 2009 | 10:49 PM
pro70z28's Avatar
Firewall Project
I'm in the planning stage. Firewall will be steel .024.
Old Sep 14, 2009 | 11:42 PM
Rebelphotog96's Avatar
I'm gonna take a wild guess and say that's not your daily driver.. Looks good though, and looks like quite a project! Look forward to the final product.
Old Sep 15, 2009 | 07:18 AM
pro70z28's Avatar
No, not a daily driver but it will be street driven.
Old Sep 19, 2009 | 05:32 PM
pro70z28's Avatar
Before I start the firewall I wanted to get the English Wheel built. Ran into a little snag though. I made up the bottom anvil assembly last night. Cut the frame parts out today. Got a couple pcs. clamped together to weld.......and then stripped the threads out of the torch head on the TIG. and it's saturday.
There goes the weekend. ...............
Old Sep 19, 2009 | 10:58 PM
SumTingWong's Avatar
Bummer.
If you have any design or layout questions, Kerry Pinkerton over at AllMetalshaping.com is your man. He's like the rainman of English Wheels, and after using one of his, my Harbor Freight wheel seems like a piece of tin.
I seem to be the only fool I know of doing a widebody kit in steel, and he and those guys over there went out of their way to help me.
Old Sep 21, 2009 | 12:05 PM
pro70z28's Avatar
Originally Posted by SumTingWong
Bummer.
Thanks for the tip.
Old Sep 21, 2009 | 02:43 PM
reamo04's Avatar
what size turbo?
Old Sep 21, 2009 | 04:28 PM
pro70z28's Avatar
No turbo. F2 Procharger.
Old Sep 21, 2009 | 04:36 PM
reamo04's Avatar
why did u decide against a turbo?
Old Sep 21, 2009 | 04:48 PM
pro70z28's Avatar
I never considered a turbo. I had a 1071 with EFI injection setting on it before I decided to sell it and go with the procharger. Nothing wrong with turbos, I just wanted to go this route.
Old Sep 27, 2009 | 09:01 PM
pro70z28's Avatar
Got a little more done on the English wheel yesterday. A guy I talked to on the phone that builds E-Wheels said if I build one it needs to be very sturdy & needs a lot of adjustment built in. So, this is what I came up with for the top anvil. It's a little more complicated than it needs to be, but I had a couple old air actuated hydraulic cylinders laying around that I wanted to make use of. I got them for free probably about 30 years ago and finally decided it's time to use what's left of them. I found one of the cylinder housings was corroded through but the ram was still good & that's what I needed for the anvil adjuster. Too bad they are shot, the cylinders are all aluminum (except for the ram).
Anyway here's the deal. I cut a couple sleeves out of aluminum round stock for the rams.
Cut a couple supports for the sleeves on the CNC
Parts pressed together. I didn't want the anvil assembly to rely on threads cut in aluminum, so I made this little pocket to hold a nut for the 3/4" ready rod that will be the adjusting screw.
Turning part of the ready rod down to 5/8'' to make an adjuster out of it.
Old Sep 27, 2009 | 09:02 PM
pro70z28's Avatar
Thanks guys. This afternoon so I drew up & cut out the adjuster wheel for the E-Wheel.
Cut the hand grips out of 1/2" PVC.
1/4" aluminum for the wheel itself.
Used fusor auto body panel adhesive to glue it all together.
Like Norm Abram says ''I'll let it cook in the clamps overnight''.
Old Oct 1, 2009 | 08:33 PM
pro70z28's Avatar
Got a little more done tonight.
Cutting out the backing plate. The slots are to index the backing plate to the adjuster assembly.
Cutting out the top cap that connects the ready rod to the rams.
Top cap completed. The brass thrust bushings are pressed in from the top and bottom. They come about .020 short of touching each other. This allows grease to be pumped in from the grease fitting.
Assembly is pretty close to done. This shows the index slots that align the backing plate to the assembly.
I also added a grease fitting to each ram cylinder just to keep everything workin' smooth.
Old Oct 6, 2009 | 12:46 PM
pro70z28's Avatar
Got a little more done last night. Parts for the top anvil.
Old Oct 6, 2009 | 09:24 PM
6SpdLT1Z's Avatar
That's some impressive machine work. Wish I could do that.
