Fiberglassed Dash Complete!!! Pics...
Old Nov 3, 2005 | 10:07 PM
  #16
1995greenTA's Avatar
Re: Fiberglassed Dash Complete!!! Pics...
That looks damn good. I bet the glare will be hell though. I want one! Id be afraid of scratching it or something with the install, or careless passengers.
Old Nov 3, 2005 | 10:24 PM
  #17
XxXTransAmXxX's Avatar
What would you guys pay for one, havin 60 hrs in it, plus materials...
Old Nov 4, 2005 | 05:31 PM
  #18
Red95Formula's Avatar
That looks good but how much does it weigh? VFN fiberglass makes a dash that just needs to be painted and prepped.
Old Nov 4, 2005 | 09:25 PM
  #19
Just add 5lbs is what I would say on to your factory dash....
Old Nov 5, 2005 | 11:20 PM
  #20
95HellBird's Avatar
I'd pay like little above $300 shipped to my door finished. but i don't know, i wanna wrap mine with a thin leather.
Old Nov 5, 2005 | 11:48 PM
  #21
$300 shipped to your door??!? Whoa talk about an insult to work...Page one stated I had $200 in materials involved, PLUS 60 hours of labor, even if you broke the $300 down to 60 labor hours, that's totalling a whopping $5.00 an hour....I'd like to see you ask someone to do the same for $300, So once you take $200 for materials that leaves $100 for LABOR and return shipping?!?! You wouldn't work at Burger King for $100 for 60 hrs would ya? That's a fraction of the effort this work takes....Thanks for the low end quote to judge things from though...
Old Nov 6, 2005 | 12:32 AM
  #22
95HellBird's Avatar
lol, sorry thought you said u had $20 not 200 but i was thinking it wouldn't take you 60 hours to do something you know how to do, plus the number 1 reason i said it is i am CHEAP, lol...If i did have the money though I would pay around $750 for it....still probably not what you'd want though
Old Nov 6, 2005 | 07:45 AM
  #23
$750 is fine....It would still take close to 60 hrs, because you want to make sure all pins holes in the filler are filled, as well as sanding prep work takes 80-90% of the time up in a job like this, I sanded from 80, 180, 220, and 320, on all resin, filler, and glaze layers, then again after 3 coats of high build, and once more after a final coat of high build getting it all to lay flat, as well at time being ate up by the materials curing....
Old Nov 6, 2005 | 08:43 AM
  #24
91 Camaro RS's Avatar
That looks nice, that that supposed to be a replacement for the stock dash? You probably could make a business out of making and selling those.
Old Nov 6, 2005 | 06:19 PM
  #25
Brangeta's Avatar
Geez... and to think I have trouble just fixing scratches in the paint. How do you guys know how to do this stuff?!
Old Nov 21, 2005 | 10:32 AM
  #26
CamaroCasanova's Avatar
Originally Posted by XxXTransAmXxX
I used 80 grit to rough the vinyl up, then fiberglass resin to fill in the Airbag seam, and AIR BAG lettering, then used resing all over sanding it to 220, then regular filler till 220, then used a final glaze compound till 220, then shot 3 passes of High Build Epoxy Primer, and sanded it to 220, then another pass of High Build, then up to 320, then 3 coats of color, and 2 coats of a high Gloss Polyurethane clear....
All of the interior will be the same way....
Ok, so I started some experimentation with this this weekend, and I don't see why you can't just sand the actual plastic parts down then prime with flexible primer then paint, like you would a plastic car bumper, as an example. The only places you would need to fiberglass would be the vinyl stuff-the airbag. Am I missing something here, is that how you did it, or did you resin everything?? It seems to be more work if you resin everything, is there any reason if you did resin it all to do that??
Thanks!
Old Nov 21, 2005 | 10:34 AM
  #27
I used Fiberglass Resin Jelly on the whole thing, then filler, and the glazing compound to fill in the lil pin holes. I never said you couldn't do plastic that way, you will need a High Build Primer for ti to fill in the imperfections, I recommed DuraTec cuz it's flexible, and known for it's levelling properties...The TA dash is vinyl hince why I did it this way
Old Nov 21, 2005 | 12:17 PM
  #28
Cool thanks
I forgot the TA dash is vinyl. Thanks for the primer recomendation too.
Old Nov 24, 2005 | 12:11 PM
  #29
Brangeta's Avatar
I'm no professional OBVIOUSLY but I wouldn't recommend just smoothing out the plastic. The plastic is already thin and kind of cheap, it would probably be more luxurious if you just covered it with resin and such. Plus, what if you smoothed it out and you had somebody in your backseat, and they accidently put their elbow through the thin plastic? That would suck!
Old Feb 26, 2006 | 02:04 PM
  #30
luckyou03's Avatar
hows the progess of the rest of the interior coming?
