Engine Detailing
Old Jun 21, 2004 | 03:08 PM
Gibzilla's Avatar
Engine Detailing
What is the best way to detail an engine. I want to detail my LS1, and I was wondering if it is ok to use Gunk and a hose down.
Should I cover anything up before hand. I do not want to short out or reuin any electrical parts.
Thanks in advance.
Old Jun 21, 2004 | 03:32 PM
joed4640's Avatar
I use simple green, wire brush and a TON of elbow grease. when everything is clean i use a SPRAY bottle w/ water (no hose) and a cloth to cover up electricals when spraying. wipe off. then...
the secret ingredient: WD-40
When everything is clean spray on some WD-40 on metal/plastic (no electrical stuff) in nice even coats (dont wipe it off....unless it starts to run/drip) you will be AMAZEDwith your results
BTW: i know it sounds strange, but i leared from a very experinced car detailer who really knows his stuff
Old Jun 21, 2004 | 11:59 PM
PDCamaro318's Avatar
CD-2 Detailing Spray is good for detailing, use Simple Green to clean it up with or you can use the CD-2 degreaser. Let us know how it turns out.
Old Jun 22, 2004 | 01:16 AM
JackZ.Twenty8's Avatar
Yep, CD2 works wonders! It is easy to use, and the results are phenomenal.
Old Jun 22, 2004 | 06:53 PM
94ZGRNMCHN's Avatar
I wipe it all down by hand with simple green,and to finish it off I spray it down with armourall fire it up and get her nice and hot,the armourall turns in to like a clear coat with the heat under the hood. Been doing it for years,give it a try.
Old Jun 22, 2004 | 08:51 PM
Gibzilla's Avatar
Will try th esimple green. With few dogs around the house I think that is the safest way to go.
Thanks for the inputs.
Old Jun 23, 2004 | 01:02 PM
TonyJ's Avatar
Originally posted by joed4640
I use simple green, wire brush and a TON of elbow grease...
A wire brush...?
Better not use an old school wire brush!
It'd have to be some REALLY soft brass or something. I wouldn't use anything stiffer that a toothbrush unless I was cleaning an aircraft carrier or something...
Old Jun 24, 2004 | 08:29 AM
joed4640's Avatar
.....I use it to clean metal parts (intake manifold throttle body alternator) its small like a toothbrush- not sure what the 'brissles' are made from tho (def not brass)--- works great, whats wrong with that?
Old Jun 24, 2004 | 08:52 AM
TonyJ's Avatar
You didn't specify what you were using it on in your first post. In fact, the "...when everything is clean..." comment makes it sound like you use it on everything...
So a rookie detailer might go out, buy a wire brush and proceed to scratch the hell out of their engine compartments paint and other finishes.
Old Jun 24, 2004 | 09:38 AM
joed4640's Avatar
I think its common sense- but you are right, i defanatly should have made myself a little more clear.
DirtyDaveW
Dec 1, 2016 05:37 PM
Sergio
Jan 27, 2016 04:27 PM
Jazsun
Dec 29, 2014 12:14 PM
hotrodyou1
Dec 20, 2014 10:05 PM
