Engine Compartment Clean up
Old Jul 7, 2009 | 02:42 AM
SmokeyBlaZe's Avatar
It is a mess under my hood. What are some things I can do to organize and clean everything up a bit? Is there anything I can do to free up some room? I already know I need to re-route the power wire to go through the passenger side and the red and blue wires by the brake fluid are about to be hooked up so they will be out of the way. I know I need some greased lightning too!
Old Jul 7, 2009 | 07:06 AM
MEAN LT1's Avatar
Theres going to be alot of simple green in your future. Being that you have a white car everything is going to show. I would do something with that Sub Wire going across the engine bay. Its just going to require alot of elbow grease and cleaning supplies.
Old Jul 7, 2009 | 09:54 AM
StripedFomula's Avatar
lots of scrubbing. second on the sub wire. i bought some aluminum polish and polished the fuel rails, it really made them stand out. i also got some polished valve covers.
Diamhea's Avatar
Lot of work ahead! But it can be fun. LT1 engine bays nowadays seem all too dirty, so you will have a lot of satisfaction after completing the job. Polishing all of the metal (fuel rails, AC lines , etc.) will be the most beneficial. Prepare to spend a good couple hours on it.
Old Jul 7, 2009 | 10:52 AM
Brangeta's Avatar
Just clean and replace the worn out parts, it'll be the best use of your time and look best in my opinion. My sister's engine bay isn't completely clean, but after replacing the red junction block on the left and cleaning the bay out with some cleaner, it looks a lot better.
I just used some weak cleaner (grocery store brand orange colored and scented multipurpose cleaner/degreaser), some paper towels, a toothbrush, and a water spray bottle full of water. Simple Green seemed more powerful than I was willing to use.
Old Jul 7, 2009 | 11:47 AM
Diamhea's Avatar
Where did you get the junction block!?!?!
Old Jul 7, 2009 | 11:53 AM
Brangeta's Avatar
I ordered it from the local chevy dealership. See this topic for all the information including part number:
https://www.camaroz28.com/forums/sho...d.php?t=687455
Old Jul 7, 2009 | 12:34 PM
Thumbs up
Nice write up
Old Jul 7, 2009 | 08:31 PM
userchemical's Avatar
Old Jul 7, 2009 | 08:45 PM
Diamhea's Avatar
Also Smokey, run the amp power wire down the passenger side.
Old Jul 7, 2009 | 08:47 PM
Did you remove the fuel rails when you polished them?
Old Jul 7, 2009 | 08:49 PM
true.
Old Jul 7, 2009 | 09:43 PM
yeah, i unbolted them but left the fuel lines hooked up and just polished them in the car. it would be a lot easier to unhook the fuel lines but i did not have the tool and didnt want to go and buy it. i also did the a/c lines while i was at it. just takes a lot of rubbing with the polishing compound
Old Jul 7, 2009 | 09:49 PM
What compound did you use? It looks great
Old Jul 8, 2009 | 07:01 AM
n2omike's Avatar
Lots of work and time but it can be done heres some of mine.
This is with some work done.
Done
