Emblem mounting
Old May 10, 2006 | 06:57 PM
00Z28SS's Avatar
Emblem mounting
I have an emblem I have to mount on my GTP. Any suggestions what I should use to mount it with (tape, glue)?
Old May 11, 2006 | 03:36 AM
Brent94Z's Avatar
Super Moderator
Re: Emblem mounting
Shoe Goo
You can get it at Wal-Mart in the shoe department. Works great!
Old May 11, 2006 | 11:50 PM
CK_Z28's Avatar
Re: Emblem mounting
Originally Posted by Brent94Z
Shoe Goo
Whoa...thats a first...brent using the remedy for all...
Old May 13, 2006 | 08:51 AM
EviLBoX's Avatar
Re: Emblem mounting
I used 3M emblem tape from Sears and that stuff works great.
Old May 13, 2006 | 09:38 AM
Z28LT1_Just_Nasty's Avatar
Re: Emblem mounting
Hot glue gun? If you screw up you can just scratch off the extra.
Old May 13, 2006 | 01:59 PM
94Z28WP's Avatar
Re: Emblem mounting
GOOP... I've used it for years and never had a problem with anything coming loose... I glued on one of my Z28 emblems with it 2 years ago and it's still on.
Old May 15, 2006 | 03:17 PM
Brent94Z's Avatar
Super Moderator
Re: Emblem mounting
Shoe Goo is similar in that if you want to remove the emblem you just peel it off and then peel off the Shoe Goo! It is a bit stronger than hot glue as well. I've used hot glue for a lot of things but I prefer Shoe Goo for emblems
Old May 17, 2006 | 05:48 PM
Drew '97 Z28's Avatar
Re: Emblem mounting
I have a similar question...I picked up a set of fender emblems from a '69 and was wondering what's the best way to mount those in place of the stock ones. Would I be best served by grinding off the pins and mounting them with adhesive? I' really don't want to drill mounting holes in my fenders if I don't have to.
Drew
Old May 18, 2006 | 09:15 AM
xstoyz's Avatar
Re: Emblem mounting
Drew,
To answer your question. I am in the process of doing the same thing. I used a dremel to grind off the pins on the back. Since the emblem is holow i used a 2 part epoxy syringe to fill the voids, I purposly over filled it. After the epoxy cured, i used the dremel again to gring it level with the sides of the emblem. This left me with a level surface that was ettched enogh for either emblem tape or goo adhesive to stick well to.
I hope this helps a little.
Old May 19, 2006 | 04:34 PM
00Z28SS's Avatar
Re: Emblem mounting
Thanks for all the replies!
Old May 19, 2006 | 06:19 PM
Re: Emblem mounting
Originally Posted by xstoyz
Drew,
Thanks for your help...much appreciated!!
Drew
G-BODYT56
Jan 14, 2022 11:14 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 23, 2015 06:09 AM
War Engine
Sep 18, 2015 07:28 PM
Daluchman1974
Sep 11, 2015 06:12 AM
