Do you think this can be fixed?
AAHHH!! I understand. Just hang in there man. Way to much money needed to fix that one. There are deals to be had. I got mine for 4k. It had 115k miles. Besides a slow window motor, non working power seat, and new tires, it didn't need anything else.
You should of bought it.That realy wasnt even that bad.As far as structual damage that would of had to be cut out and welded in would of been your radiator core support.All the rest of that could of been pulled out on a frame rack. You could of had a body shop do all the structual repairs for 1000-15000$ Wish I could of came acrossed that one
Not a chance. You'd have more than that in parts to fix the unibody. Not to mention the whole front end including motor and cradle needed to be removed to fix something like that. Core support is trashed frame horns are bent in and down(a bitch to repair) the bumper support is trashe and as was said before from the shock towers forward they are probably pulled inward. that's all assuming this thing was a straight on hit, if it was off to one side or another the front end likely has all that damage shifted one way or another.
What did they want for it BTW?
You'll be glad you didn't get it. My car has been wrecked....twice....and I hate that I still have it. About the second time you find something slightly off line or a bolt hole a little cockeyed it's not worth dealing with.
*First I assume you ment 1500. 1k to 15K is a pretty big leap.*
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
