Do led bulbs burn brighter than regular ones?
Old Apr 23, 2003 | 10:57 PM
KillerTA's Avatar
I have blackout taillight covers on my TA and the brake lights arent bright enough. If I switched the regular bulbs with white led bulbs would that make a difference?
Old Apr 24, 2003 | 12:23 AM
OctaneZ28's Avatar
Disciple
LEDs will be dimmer than regular bulbs.
I converted my front turn signal bulbs to LEDs and they're no where near as bright as regular bulbs.
Old Apr 24, 2003 | 12:28 AM
Calli's Avatar
what if we switched to a brighter burning bulb of some sort... maybe a hyper white type or something ? ... does one even exist?
Old Apr 25, 2003 | 09:36 AM
fbird95's Avatar
With the LEDs you wont have to worry about burn outs.
Old Apr 25, 2003 | 12:24 PM
94BlackBowtie's Avatar
Yes they exist - search Google, MSN, any other search engine for "Hyperwhite XXXX Bulbs" (XXXX=bulb size, probably 1157, 1156, etc. - look that up at www.sylvania.com).
A search for that though will yield results. Stick with the Nokya's or Raybrig's if you can.
Old Apr 25, 2003 | 12:26 PM
catsnet's Avatar
they are brighter only if you look straight to it any other angle they'll be dimmer and from the side you'll barely be able to see them at all. They do take wayy less power and they last way longer.
Formula Steve
Sep 19, 2023 08:31 AM
cmsmith
Sep 14, 2015 09:25 PM
4586
Aug 24, 2015 11:04 PM
Henson071
Aug 4, 2015 09:32 AM
alphaauto
Jul 26, 2015 04:40 PM
