do 3rd gen calipers LOOK like 4th gen calipers
My brother wants front caliper decals, so I'm going to get them for him for his birthday. But these say they are for a 4th gen, will they work on front 3rd gen calipers? I cant remember what the calipers look like.
Pic is of 4th gen caliper with decal http://www.bfranker.badz28.com/vinyl/May2109.JPG |
No. Unless it is a 1LE thirdgen then the front brake calipers are tiny little one piston iron calipers.
Originally Posted by 91Z-28
(Post 4581385)
The calipers are just the one piston. I guess they dont have to look like a 4th gen caliper, just be able to work with that sticker. |
Take some measurements and talk to Brent. I'm sure he can work something out.
Originally Posted by ReNxWar
(Post 4581395)
this is a 1991 caliper, looks like it will work...right http://www.ecklerscamaro.com/Images/wca/720082.jpg |
Originally Posted by jawzforlife
(Post 4581400)
my brother's birthday is on the 16th, so I need these right away.
(Post 4581403)
It doesn't look like theres even room for a decal on there. It MAY be around the same size as a rear caliper of a 4th gen.
Pretty much. For a while I had my 98-02 F-body brakes on the rear with the stock 91 brakes on the front before I had my C5 brakes. The 98-02s were probably about the same size, maybe a little bigger. But the rotor definitely was at 12" vs 10.5". It didn't look THAT bad though, since I'm running 18s in the back and 17s up front it was kind of an optical illusion thing. I doubt a sticker would fit on a stock caliper, that thing is TINY. |
what if I got the "CAMARO SS" decal, and cut off the SS part, to make it smaller
http://www.bfranker.badz28.com/vinyl...als_Camaro.jpg |
(Post 4581462)
http://www.bfranker.badz28.com/vinyl...als_Camaro.jpg http://i3.tinypic.com/w9uz2t.jpg http://i3.tinypic.com/w9uzom.jpg I don't see any way in hell even a chopped sticker would fit on a stock 91 caliper. |
oh I didn't know a 4th gen caliper was the same size as a C5 caliper.
(Post 4581490)
so if I can get him to make the sticker smaller to fit a 3rd gen, what size do they need to be?
(Post 4581504)
(Post 4581509)
Look at that first pic I posted. If he were to make a sticker able to fit on that thin little piece of metal I'm sure it would be too small to read unless you were changing the tire. Looks like it would have be less than 1" tall.
https://i50.photobucket.com/albums/f...ts/caliper.jpg |
may want to get a radius measurement from the center of the hub to the decal location that way you get the correct arc.
