decision help QUICK!!
Old Apr 8, 2006 | 12:59 PM
SixSpeedShifter's Avatar
Exclamation decision help QUICK!!
Hey guys. My 94 formula was just hit in the right rear and I need a new door (thanks to being fibergalss). I figured I would use this opporitunity to possibly convert to the two-speaker-per-door setup. I remember seeing this panel somewhere but after an hour of searching, I got nothing.
Does anyone know which doors will fit my car and know of anywhere I can see pics of each? Thanks ALOT!
Old Apr 8, 2006 | 04:43 PM
Re: decision help QUICK!!
Oh, if I do this conversion of the passenger side, will I have to get a whole new driver side door as well or just a new interior panel? Thanks again.
Old Apr 8, 2006 | 08:19 PM
Koby's Avatar
As far as the door I don't think there is any difference in the two frames. The two speakers are all in the door panels, which can be found on ebay. There is no extra space needed for the tweeter. I just put a set of them in my Z and they fit like a glove.
Old May 11, 2006 | 03:15 PM
hot white z's Avatar
Koby, did you put firebird doors in your z or just do the door panel conversion? I want to know if the doors are directly interchangable or if you're stuck with having to swap out the door panels when you want to go this route.
Old May 11, 2006 | 05:07 PM
Z95m6's Avatar
The doors are different. Swapping out door panels is 100x easier than doing door swap.
IndyZman
Oct 22, 2015 02:17 PM
WobblySausage
Oct 7, 2015 02:44 PM
68camaroboltz
Oct 5, 2015 11:56 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
NewsBot
Sep 14, 2015 09:20 AM
