daytime running lights
Old Feb 21, 2007 | 12:16 AM
jer4251's Avatar
First of all i would like to say, I have found and read the install guide on bfranker's site and that is really not what i want to do.
I want to have the 97+ daytime running lights on my 1996 SS. I do NOT want to install a secondary switch to control anything.
I'd like to make it just as a 1997 and up would be. 1 year and a new interior couldnt have changed that much that i cant do a true swap for all origonal parts.
does anyone know what all i would need to buy or do to get them to be exactly like my 1997?
thanks
Old Oct 15, 2010 | 10:24 AM
jordankeck's Avatar
I know this is an old thread, but does anyone have a write up for adding DRL's to the front parking lights like the 97+? I have been searching around and all that I can find are complaints about the DRL's and instructions for removing them. I would like to add them and am hoping that someone has already done this and can quickly explain. I know that adding DRL's to the front parking lights is as simple as a relay to turn on the parking lights but I would like them to function as the factory DRL's do, minus the auto headlights. I would like for them to come on when the ebrake is down, but go off when the headlights are turned on. This will likely include a series of relays, which is why I am hopeful that someone has already worked the details out. Any help would be appreciated!
Old Oct 16, 2010 | 01:16 AM
Procharged94Lt1's Avatar
I got to this company off BFranker's site- hopefully nobody minds...
http://www.webelectricproducts.com/products.htm
If you check out their products they have DRL kits there, one for a corvette actually. You might be able to modify it to work with your car.
I'm not an electrician so I'm not so good with the wiring/relay configuration you would need.
blac94Z
Jan 16, 2015 11:03 PM
97z28k&N
Jan 9, 2015 04:58 AM
dirtybird81
10
Jan 6, 2015 09:31 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
