daylight interior pics!
Old Jan 2, 2006 | 03:24 PM
BigggD222's Avatar
What my interior looked like before I painted it again and before it got broken into....
After with newly painted pieces!
Old Jan 2, 2006 | 03:28 PM
meissen's Avatar
Re: daylight interior pics!
Very nice!
Old Jan 2, 2006 | 03:31 PM
BigggD222's Avatar
It took a lot of work and sanding to get the spray painted silver off the pieces! But here are the steps I used after I got the paint off!
*Sand with 240 grit
*Wetsand with 400grit
*Coat of sandable primer
*Wetsand with 400
*Wetsand with 600
*Another coat of primer
*Drysand lightly with 400
*Wetsand with 600
*Sprayed 3 coats of silver basecoat with spraygun
*Lightly sanded it with 800 grit then 1000.
*Sprayed one last coat basecoat.
*Sprayed a coat of Anodized Smoke Silver with spraygun
*Sprayed with 3 coats of clear with spraygun.
*Let dry
*Replace
meissen's Avatar
Any info on what spraygun and compressor you used?
Old Jan 2, 2006 | 03:34 PM
BigggD222's Avatar
Thanks for the compliment man! Not a lot of info, it is my dad's stuff, the compressor is about 30 years old and wieghs about 500lbs lol. And the spray guns are around 10 years old! Everything still works great tho!
Old Jan 2, 2006 | 03:35 PM
km9v's Avatar
Why did you paint them remove paint from the trim pieces? I think the silver looks good.
Old Jan 2, 2006 | 03:42 PM
BigggD222's Avatar
The silver paint was fading, chipping, and it stained easily! It is almost the same exact silver, just in certain lighting its got a smoky color to it! I wanted to do something different. Now with a clearcoat too I can wax it and keep it look good for a lot longer than the spraypaint crap did!
Old Jan 2, 2006 | 04:58 PM
SinisterSix's Avatar
what type of paint did you use it looks nice i want to paint mine black i'm just scared its going to come out looking cheap... i want it to be as shiny as the out side of my car. . .
Old Jan 2, 2006 | 05:45 PM
BigggD222's Avatar
I used PPG Silver and Smoke Metallic as the final coat before I sprayed the clear!
RUENUF
May 25, 2016 08:10 PM
Fastbird93
Apr 9, 2016 07:01 PM
RUENUF
Mar 13, 2016 03:39 PM
cmsmith
May 17, 2015 06:15 PM
cmsmith
Mar 16, 2015 02:34 PM
