daylight interior pics!
Re: daylight interior pics!
It took a lot of work and sanding to get the spray painted silver off the pieces! But here are the steps I used after I got the paint off!
*Sand with 240 grit
*Wetsand with 400grit
*Coat of sandable primer
*Wetsand with 400
*Wetsand with 600
*Another coat of primer
*Drysand lightly with 400
*Wetsand with 600
*Sprayed 3 coats of silver basecoat with spraygun
*Lightly sanded it with 800 grit then 1000.
*Sprayed one last coat basecoat.
*Sprayed a coat of Anodized Smoke Silver with spraygun
*Sprayed with 3 coats of clear with spraygun.
*Let dry
*Replace
*Sand with 240 grit
*Wetsand with 400
*Wetsand with 600
*Wetsand with 600
*Let dry
*Replace
Thanks for the compliment man! Not a lot of info, it is my dad's stuff, the compressor is about 30 years old and wieghs about 500lbs lol. And the spray guns are around 10 years old! Everything still works great tho!
The silver paint was fading, chipping, and it stained easily! It is almost the same exact silver, just in certain lighting its got a smoky color to it! I wanted to do something different. Now with a clearcoat too I can wax it and keep it look good for a lot longer than the spraypaint crap did!
what type of paint did you use it looks nice i want to paint mine black i'm just scared its going to come out looking cheap... i want it to be as shiny as the out side of my car. . .
cmsmith
May 17, 2015 06:15 PM
cmsmith
Mar 16, 2015 02:34 PM
