dash pad install on 94 z28
Old Jul 23, 2010 | 10:21 PM
dragonman712's Avatar
Cool dash pad install on 94 z28
i'm a new member, but an older guy and long time camaro builder. i need a little help with installing a new dsah pad in my 94 z28. it's a complete resto i'm doing with my 8 yr old grandson. any help appreciated. thanks, dragonman
Old Jul 24, 2010 | 11:57 AM
MeenZ28's Avatar
Just the upper pad (large flat piece closest to the windshield) or are you replacing the entire dash?
Old Jul 25, 2010 | 12:29 PM
Brangeta's Avatar
I "believe" you have to remove the A-pillar covers, which seems to be the common action that actually ends up cracking the dash pad.
Old Jul 25, 2010 | 07:09 PM
Procharged94Lt1's Avatar
Its a two-point process- the a-pillar covers have a notch on the inside that the upper dash pad rests in. They can't be removed until the upper dash pad is lifted slightly.
IMO- the best way to insure you don't ruin your dash pad is to lift the corners slightly first- it will allow you to remove the a-pillar covers which in turn give you considerably more room to maneuver the dash pad and not have to flex it so much getting it out.
Hope that makes sense-
chuyz28
Parts Wanted
Jan 7, 2015 05:25 PM
nikko
Dec 2, 2014 03:43 PM
Double aught
Parts Wanted
Nov 23, 2014 06:11 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
