Damaged 93 Camaro swapped to 98 Camaro frontclip
Old Nov 15, 2006 | 02:20 AM
  #16
sbca96's Avatar
Honestly it wasnt that difficult to align. I put the hood on, then aligned the
fenders to the hood. Then when I put the nose on, I had to lower the hood
to sit flush with the nose, and then lower the fenders to match the hood. It
sounds like a lot of work, but the hardest part is opening the closing the hood
each time you want to move the fender.
Tom
Old Nov 21, 2006 | 04:19 PM
  #17
pistolpete69's Avatar
Originally Posted by sbca96
I just used a 1/8 th drill bit, and ran one of the self tapping screws that held the old headlight assy
onto the front structure. BUT .. Do yourself a favor and REMOVE the battery, pull the harness up
out of the way behind the sheetmetal on the passenger side!! I drilled the hole and THEN realized I
might have drilled into some wires!! I got LUCKY ... the bit went between everything. I used a piece
of plastic in between the screw and the harness, and also dremeled off the sharp tip after I made
the tapped hole into the sheet metal :
New brackets ordered from GM. These are the ones that the guy forgot to pull off for me :
That big gray piece holds the nose on, make sure you get that too!
Got the silver fender on :
Got the gold fender on, but there was a problem .....
Tom
TomWhat is that "That big gray piece holds the nose on, make sure you get that too!" called or its parts number???
I cant tell which piece it is in the drawings???
Thanks Pete.
Old Nov 22, 2006 | 04:21 PM
  #18
sbca96's Avatar
Looks like its part number "56" on the exploded view posted on the tutorial
thread. Picture "frontconversion13.jpg". FYI, the GM dealer had a totally
different exploded view with different find numbers.
Tom
Old Nov 23, 2006 | 09:29 PM
  #19
that other support panel
Yeah the drawing I was looking at also had it as another part number and listed as item 50 - Support Bracket 10276561...???
Also, are the indicator lights the same as I cant seam to be able to fit my 93 model indicators on the 02 bumper??? Am I going crazy or what?
PEte.
Old Nov 24, 2006 | 04:50 PM
  #20
Bayer-Z28's Avatar
Good work. As far as P/N's. Check my stickey in the LSx Tech room. I ahve a couple of inks in there for a page w/ a LOT of P/N's in there. It's a bumper support, btw.
Old Nov 24, 2006 | 08:51 PM
  #21
sbca96's Avatar
PEte.
You mean the front turn signals? They are the same ones, the molded in part
numnner & DOT number both say "93" on the 98 ones I got. I didnt bother to
pull them and just used them as is. I did notice that the light plug was VERY
hard to twist into the 98, I started to think they were different, but then it
finally twisted in and all was good.
Tom
Old Jul 17, 2007 | 07:41 PM
  #22
mattgdg's Avatar
Getting ready to this conversion and the only bumper support I can find shows it as being the same on the 93-02 cars. Is there a different bumper support used on the 98-02 or will the one I have on my 95 work?
Just want to clarify before I get stuck in the middle of doing it
Old Oct 1, 2007 | 02:24 AM
  #23
sbca96's Avatar
Only 2 months late replying on this .. I dont get on here much.
From what I saw, the steel bumper piece was different.
Tom
Old Oct 20, 2007 | 02:37 AM
  #24
kennedy50's Avatar
does anyone know what the big gray piece is called that holds the nose on or its actual GM part #...and is the bumper support really needed if you dont plan on hitting another car
Old Oct 20, 2007 | 05:36 PM
  #25
Brangeta's Avatar
LOL! I don't know if you meant that to be funny, but I just laughed out loud when I read that. Good stuff!
Old Oct 20, 2007 | 07:43 PM
  #26
razor02097's Avatar
well the bumper pad helps keep the front end shape.
I though the same way when I first read it
Old Feb 6, 2009 | 04:17 PM
  #27
sbca96's Avatar
Updated the pictures.
Tom
Old Feb 6, 2009 | 05:22 PM
  #28
PoorMan's Avatar
Downgrade imo but if you couldn't get a LT1 front end then I understand.
Old Feb 7, 2009 | 12:15 AM
  #29
sbca96's Avatar
To each their own, I never liked the Raccoon front end, too pointy and out
of balance with the rear. Raising the front end lines seriously helped the side
view. Personally I would rather had seen single headlights, to go more toward
the 70 Camaro, but its all good.
Tom
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
