Custom one off 3rd gen aftermarket gauge cluster. Pics inside.
Me and my friend charlie (stangkilla91) spent all yesterdsay and today buying the stuff and fabbing up this custom gauge cluster for charlies thirdgen. We used 1/4" aluminum plate stock and cut it to size. Then we used a 3" hole saw and a 2" hole saw to cut the rough holes. Final touches to the holes were made with a dremel using a carbide bit. The leds came from radioshack and were wired with 640 ohm resistors and placed in a chrome led holder. The switch panel goes inside the console. The switch panel uses the same typ leds and resistors and led holders. The switches are just plain toggel switches. The gauges are Auto Meter's Phantom II series. The gauges in the cluster are: Speedo, Volt, fuel level. The ones in the pillar are oil pressure, tranny temp and water temp. The tach is a shift light/digital tach by autometer.
cluster layout
final layout
drilling the holes
almost there
switch panel layout
Me touching up the gauge holes with the dremel.
Beginning to powder coat the panels and my 5 point harness buckels
More powder coating
Even more powder coating
cluster layout
final layout
drilling the holes
almost there
switch panel layout
More powder coating
Continued.
Switches and leds
Finished cluster panel
Cluster panel lit up
More cluster panel
switch panel
Tripple pillar pod and gauges
Auto meter Digital tach/shiftlight combo unit
Switches and leds
More cluster panel
switch panel
nice! very clean looking and looks like a race car. im assuming the 2 green LEDs are the left and right turn signal and the blue is high beams on? but im wondering what the yellow and red ones are also?
and i gotta see that in the car in day.
ill definately post pics of it when im through, hopefully it will be soon, but who knows, these things seem to take longer to finish than expected. like jeff said, i just run at t&t nights for fun, but plan on getting into a class when i get it back on the road. thanks for the support guys.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
ddr698
Jan 31, 2015 10:58 AM
