Cracked bumper... needs replaced?
Old Apr 3, 2003 | 06:13 AM
Billy Badass's Avatar
From: Carbondale, Illinois (home) Champaign-Urbana, Illinois (school)
Hey guys! My front bumper looks so scratched up and pathetic right now, this summer I was going to have it sanded and repainted. I found a small crack, maybe about two inches, running from the passenger side turn signal down, and just sorta ending. I suppose I'll have to have the whole darn bumper cover replaced if I want that taken care of? There's no epoxy or anything like that which could be done, is there? Thanks!
-Bill
Old Apr 3, 2003 | 01:01 PM
bad93z's Avatar
When I got my front end fixed they had to replace the bumper cover...and mine only had a tear that was about an inch long
Old Apr 4, 2003 | 08:13 PM
LT1Bunny's Avatar
there is some stuff you can buy if you go to your local autobody supplier and ask for some plastic bumper cover filler. at first i tried just sanding it down and then making it smooth and feathering it in with the rest of the body...but it evenually cracked 5 months later. then i tried body filler, that last about 8 months. then i went ahead and spent some extra money on the bumper filler and its spot less...1 year down the road and not a crack, not even a spider crack.
Old Apr 4, 2003 | 11:18 PM
93.FORMULA.WS6's Avatar
Yes it is possible to fix the crack. but you will have to drill a small hole at the end of the crack. Use 1/8 " drill bit. This will keep the crack (tear) from going any further. Next you will need to "V" the crack. What I mean is cut a groove in the crack but not all the way through. It will be best to use a die grinder like the kind used to port heads. however do not grind all the way through the bumper cover. The groove should be probably a 1/4 " wide and about 1/8" deep. Next hold the bumper stable where you can epoxy it and in is in the right shape. Then place some tape on the back side of the bumper cover, this will help the application.
I would reccomend using 3-M Brand adhesive. I have always had good luck with thier flexible repair products. You get what you pay for so if may be allitle more expensive but it is still cheaper to do the repair just once. You are going to want to use a semi-rigid type epoxy for your bumper cover. allow ample time to dry before sanding the product. and it may be needed to put a THIN wipe of body filler over the plastic repair to eliminate Pin holes in the epoxy. Finish your sanding scratches with 180 grit before primer and use a flexible primer..........
If you want your bumper yo look flawless it may be in your best interest to leave it to us pros. But that is just my 2 cents worth. And good luck,
Chris Webster
Old Apr 9, 2003 | 10:07 AM
furr95z's Avatar
My brother, a mechanic in the Cleveland, OH area, suggested these 3 sites for auto body parts:
www.expressbodyparts.com
www.autobodypartsonline.com
www.autopartsland.com
I was browsing these sites this morning looking for a front bumper cover for my 95Z and it looks like I can get one in primer for app. $85.00 plus shipping. All I would need to do would be to install it and have it painted.
Klypto
Mar 30, 2015 02:09 PM
rjc1629
Jan 27, 2015 10:46 AM
hotrod 5210
Dec 22, 2014 07:28 AM
squarehead
Nov 21, 2014 08:02 PM
