corners?
Old Aug 22, 2006 | 07:56 PM
jrangel's Avatar
corners?
How do you take off the orange corners off Ls1's?? mine dosent work and i hate the look of the car like that..? Can the bulb be replaced witd like any ordinary ones u buy at the gas station..?
Old Aug 22, 2006 | 09:44 PM
94_PatriotRed_Z's Avatar
Re: corners?
yes you can use a bulb from any parts store. It should be a #194 or #1156 depending on which bulb is burnt. You have to remove the splash gaurd on the bottom of the car(about 10 bolts each 10mm) then you should be able to reach up there and twist the bulb out, or if you want to remove the whole corner marker there are 3 7mm or 8mm screws that hold it in(2 on the bottom, 1 on the back)
Old Aug 23, 2006 | 11:51 AM
jrangel's Avatar
Re: corners?
wow sounds confusing haha but i get the point... thanks
Old Aug 23, 2006 | 01:03 PM
pinball-1's Avatar
Re: corners?
it's very hard to do IMO. I tryed it and couldnt get any of the screws off with out breaking the bumper (which I did twice). Mine were rusted pretty badly though.
Old Aug 23, 2006 | 01:34 PM
Re: corners?
its not hard just a PITA, I just took mine off last week so I could night shade them.
Old Aug 23, 2006 | 03:44 PM
ImportKILLER's Avatar
Re: corners?
It isn't an impossible task but it certainly is a little tough the first time. I've changed my corners/bulbs so many times that I can do both sides in about 20 minutes start to finish.
For me, the hardest part is my neck getting tired from looking upward into the bumper.
Old Aug 23, 2006 | 10:04 PM
hllywd's Avatar
Re: corners?
I found it easier taking the headlights out and getting at it from the top.
Lot less screws than the bottom.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Sep 18, 2015 04:01 PM
whitehooptie
Aug 10, 2015 07:02 AM
Henson071
Aug 4, 2015 09:32 AM
Boss002
Jul 24, 2015 10:47 AM
