corner light removal
Old Apr 16, 2011 | 11:15 PM
rv93's Avatar
i just got some new corner lights, and am trying to install them. I found out how to remove them, but its not working for me. i got all of the screws out, and the housing is definitely loose. but i can't seem to get it out of the cradle sort of thing. I've tried twisting and tilting it every way i can think of, with no success. Its an 02, if that makes any difference. Anybody got any suggestions? thanks
Old Apr 17, 2011 | 07:33 PM
TD95Z's Avatar
Re: corner light removal
If you have taken all three screws completely out of each one, they should come out fairly easily. If any rocking is needed, it should be minimal. I pulled a set off a junkyard car completely blind without an issue, so I'm not sure why yours are being difficult. Try to pull the rear of the housing upward and they should pop right out.
Old Apr 17, 2011 | 08:42 PM
rv93's Avatar
ive spent a total of 2 hours over 2 days pulling up in every way i could think of. the inner part cant come out after being pulled up because of the bumper impact absorber (the gray foamy thing), and the outer part cant swing out because of a metal bar thing...not quite sure what thats for. was the car you got them off an 02? maybe mine is just "special"
Old Apr 18, 2011 | 07:37 AM
TD95Z's Avatar
I'll have to look at the 99 and see if I can figure out the issue. My personal car is a 94 TA, but I have a 99 Camaro at my disposal that I can look at/try this on. I seem to recall a small black bar that was used to brace either the fender or one of the lights on the 98-02 cars, but it's been awhile since I had the bumper off. By the way, you are trying to take these out from underneath the car, right?
Old Apr 18, 2011 | 12:26 PM
rv93's Avatar
yeah, i think thats the bar thats keeping the outer edge for swinging out. and yes, i started from underneath. when i had no luck, i also took off the headlight to see if that helped. it didnt...
Old Apr 19, 2011 | 08:31 AM
rv93's Avatar
bump. TD95Z, if you know what taking off that black bar entails, please let me know. thanks
Old Apr 19, 2011 | 09:37 AM
Wild Willy's Avatar
I came in here to post this- that by taking the headlight out, you should be able to see what you are doing, and have plenty of room.
Old Apr 19, 2011 | 11:56 AM
rv93's Avatar
i have no problem seeing. it just wont fit...thanks for your input though
Old Apr 19, 2011 | 05:32 PM
Evolution223's Avatar
Take your headlights out, it will make it much easier, just unplug the bulbs, take out the 1 bolt for each headlight and then slide the light housing inward and it pops right out, the corner lights are right there under the headlights.
I didn;t know this when I put my Clear corners in and I ended up cracking the bumpr getting them out from the bottom.
Old Apr 19, 2011 | 08:50 PM
rv93's Avatar
i did. theres just this stupid black bar on the outside keeping it from swinging out
Old Apr 21, 2011 | 12:28 PM
ZeeS7o7's Avatar
rv93.....take out the headlights like ***** said
Old Apr 21, 2011 | 04:53 PM
weird, I believe there are 2 or more bolts for each light, be sure you have all of them out. You may have to bend the bumper a bit, that's how i cracked my bumper getting my lights out.
I dont think anyone knows what black bar you are talking about, can you post a photo?
Old Apr 21, 2011 | 09:15 PM
rv93's Avatar
im pretty sure if i bend it any more, itll crack. it sounded like TD95Z knew what i was talking about. i have to take some things off to take a picture of the bar, but i will do that this weekend. thanks for the tip.
Old Apr 23, 2011 | 06:50 PM
rv93's Avatar
ok, so decided to stop being so stubborn, and tried taking them out from the top. turns out the trick is bending the bumper up a bit right under the headlights. so even though i didnt need the extra visibility afforded by taking out the headlights, it gave me the flexibility i needed. i got the new lights installed, no problem. thanks for being so insistent, guys!
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rjc1629
Jan 27, 2015 10:46 AM
Caps94ZODG
10
Sep 9, 2002 12:08 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
