Convertible Carpet ( 4th gen )
Old Oct 5, 2002 | 09:35 AM
90 Z28SS's Avatar
Has anyone actually put coupe carpet in their convertible ???
I did not think it would be this hard to find carpet . I cant find any low mile 94-96 or 2000-2002 verts that are being parted out and the ONLY place that sells new vert carpet is GM and it EXPENSIVE ! ACC does not , and has no plans to make vert specific carpet . They don't believe me when I say the floor pans are different
Old Oct 5, 2002 | 09:50 AM
Marky82's Avatar
I would also like to know. I have a 97 Camaro Convertible that I want to change the interior color of
Old Sep 28, 2004 | 07:26 AM
jeremyferguson's Avatar
Re: Convertible Carpet ( 4th gen )
anyone......anyone......bueller?????
Old Sep 28, 2004 | 09:32 AM
Marky82's Avatar
wow, talk about resurrecting an old post. I just ended up dying it myself with fabric dye from pep boys
Old Sep 28, 2004 | 10:46 AM
meissen's Avatar
vert carpet has two big holes that the vert top covers, on a coupe those holes would show up and you'd have bare metal showing..
btw what type of dye did you use and about how much did it cost you to dye the whole carpet?
Old Sep 28, 2004 | 12:08 PM
Kyle@CSS's Avatar
I have a TA conv we are parting out. Nice carpet. $100.00 plus shipping.
www.fbodyjunk.com
Old Sep 28, 2004 | 01:45 PM
www.fbodyjunk.com
what color is it???
Old Sep 28, 2004 | 01:46 PM
So what your saying is that we can use coupe carpet in a vert and just cut the two holes your talking about.......did I understand that correctly???
Old Sep 28, 2004 | 03:28 PM
Kyle@CSS's Avatar
Originally Posted by jeremyferguson
what color is it???
dark grey. I can send you pics.
Old Sep 28, 2004 | 04:40 PM
90 Z28SS's Avatar
I ended up trying to put coupe carpet in my car . An ABSOLUTE no go , the floor pans are so different the carpet would not lay right at all . Behind the back seats is the obvious different area , but around the door sills are completely different from a coupe to a vert .
Not one aftermarket company has yet to address the fact that the only way to get vert carpet is OEM or used . I called ACC a few times and they insist the floor pans are the same and they are dead wrong ...so dont look for any product from them that is vert specific
Old Sep 28, 2004 | 04:45 PM
90 Z28SS's Avatar
Jeremy - You can use vert carpet from a 97 , 98 or 99 and it will be the same color as you have now .....that is , if its dark grey . 93-96 graphite was a little darker than 97 , and 2000-2002 ebony is about 4 shades darker . If your interior is neutral (tan) ....93-96 used the same color(camel) and 97-2002 is the same color(light neutral) .
Old Sep 28, 2004 | 09:19 PM
meissen's Avatar
if you want to put it in a vert, coupe carpet will work fine, I don't even think you need to cut the carpeting... I think they just wanted to save a few extra cents so they didn't use the full carpet on a vert...
Old Sep 29, 2004 | 05:19 AM
90 Z28SS's Avatar
UUUUUUUUh , cutting the carpet isnt the problem . The little problem of it being molded completely different in alot of areas IS . Again , I have actually tried to do this ....have you ?? If you havent , I would suggest you start giving advice based of what you know , not what you "think"
Old Sep 29, 2004 | 06:09 AM
Thanks for the heads up. I have the graphite color which really gets on my nerves....I don't know why. Its in great shape(40k) but I think I would like the ebony color more. I'll have to check out what zeeya has, that sounds like a good deal......
Old Sep 29, 2004 | 06:12 AM
Thanks for that heads-up too. I probably would have ordered regular coupe carpet and beat my girlfriend to a bloody pulp when I found out it was for different pans....j/k
