Console delete, Jaz seats, and Pro Stick pictures
Old Dec 17, 2006 | 03:18 PM
12SCNDZ's Avatar
OK...These are pictures from the trial assembly.
Old Dec 17, 2006 | 04:11 PM
gt_biker13's Avatar
Might want to rehost them, they dont work.
Old Dec 17, 2006 | 04:16 PM
redneck01's Avatar
yea frank..how are things coming. my 4l60 is holding up great so far in my t/a. had in there a year..engine issues all summer so no track time.
Old Dec 17, 2006 | 04:26 PM
2000GTP's Avatar
Thats some very nice work Frank.
Old Dec 17, 2006 | 05:25 PM
gt_biker13's Avatar
Nice job. Are you putting a roll bar in there too?
Old Dec 17, 2006 | 05:59 PM
12SCNDZ's Avatar
Yup...It should be going out in a couple weeks to get the bar put in. 8 PT. with dual swingouts.
Frank
Old Dec 17, 2006 | 06:28 PM
12SCNDZ's Avatar
Click on picture for complete photo album.
Frank
Old Dec 17, 2006 | 07:32 PM
94_camm's Avatar
think someone could to something like that for a 6spd?is that new carpet?
Old Dec 17, 2006 | 09:01 PM
12SCNDZ's Avatar
Yes, it is new ACC carpet. The carpet comes with the console hole cut. I bought extra yardage of matching carpet to make my own piece for the transmission tunnel. It wasn't as easy as it looks. I had to use a piece of fiberglass mat to make the tunnel less irregular, before laying the capet. I had to use a heat gun to form the carpet around the contours of the tunnel. It was alot of work, but I wanted a Pro Stick with the exposed aluminum cover. The switch panel you see in the picture was also fabricated by me from sheet aluminum.
Frank
Old Dec 17, 2006 | 09:04 PM
94_camm's Avatar
nice work!!
Old Dec 17, 2006 | 09:16 PM
12SCNDZ's Avatar
nice work!!
Thanks. Here's a close-up of the switch panel, before I installed the purge button.
BTW, The button on the shifter handle isn't factory, either. I installed it in the ****, for my line-locs.
Frank
Old Dec 17, 2006 | 09:44 PM
gt_biker13's Avatar
Hate to tell you this, but if you baught the carpet from here you could have just cut a hole for the shifter and been done with it.
Old Dec 17, 2006 | 09:56 PM
12SCNDZ's Avatar
Every molded carpet set I checked was heat molded to a stock floorpan. Since I have removed my console brackets, and rear seat brackets, I still would've had to customize whatever I used. My carpet was also $100 cheaper than what's in that link.
I had actually bought Proline carpet that wasn't cut for the console, before buying the ACC. I wasn't satisfied with the quality.
BTW, who you got in mind for that transmission rebuild?
Frank
Old Dec 17, 2006 | 10:11 PM
gt_biker13's Avatar
You of course, only problem is shipping costs. Its about $440 each way plus what ever duty they might charge. So i was thinking on buying a rebuild kit and have a transmittion shop here install it, or i could do it myself.
Old Dec 18, 2006 | 11:26 AM
3800rs's Avatar
looks really good esp since you got the new carpet in there
