Clear Side Marker Install??
Old May 22, 2003 | 11:11 AM
Knowklew's Avatar
Question Clear Side Marker Install??
I just got my new clear side markers for the Z28 and i have no idea how to install them....Anyone wanna shed some light for me?
Old May 22, 2003 | 11:17 AM
94BlackBowtie's Avatar
Pretty Simple -
•First, just pull the 10mm headed bolts that hold on the underbody piece of the fender area. It may also help to pull the three little pins that hold the center of the front end piece on underneath. In short - just get access to the markers from the underside/inside.
•Go ahead and twist out the bulbs by their bases.
•There are three bolts/screws that hold on the corner markers. Take these out, and you are ready to pull it out.
•Stick the clear corner up in there, and tighten down the three screws.
•Twist the bulbs back in.
•Put the underside of your car back together.
Note: It isn't necessary to remove the air dam (long plastic piece that runs across the underside). You may want to remove the bolt on the end for a little easier access.
Good luck - shouldn't take no time.
Old May 22, 2003 | 11:19 AM
Knowklew's Avatar
I am talking about the fronts....
Old May 22, 2003 | 11:29 AM
Look up.
Old May 22, 2003 | 12:05 PM
Koors96Z's Avatar
I heard for the LS1 body style, its easier to take off the headlight and go in from the top. I dont exactly know how, hopefully someone with an LS1 can explain better.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
slocody
Feb 10, 2003 01:04 PM
RedLineRev
Jan 23, 2003 03:51 PM
