clear corners
Old Sep 23, 2002 | 01:22 PM
Miles-'s Avatar
clear corners
I am going to purchase some corners for the z, I think in cali you need to have colored trun signal bulbs. somone correct me if I am wrong. The question is both bulbs are not on at once right, I mean I want to have the running lights be white and put the orange ones in there when the signal is wrong. is this right or do i have to use the same bulbs?
thanks
miles
Old Sep 23, 2002 | 01:59 PM
JackZ.Twenty8's Avatar
It will look like this! There is only one bulb.
http://www.jackz28.com/myz/dsc00336.jpg
Old Sep 23, 2002 | 07:57 PM
pu12en12g's Avatar
Whatsup Miles,
I think I know what you are getting at. You want your clear corners clear correct ? And then u want the seperate FAR CORNER lights (usually used as parking lights) to blink yellow when u signal in order to be legal ? ?
I wanted the same thing, and you will have to re-wire things to get it to work. One of the problems is that it is a smaller bulb in that far corner. The dual filiment blinkers, and the relays for the blinkers are the other problem.
Old Sep 24, 2002 | 02:01 AM
Miles-'s Avatar
yeah that is what i am talking about is it hard to do, or should i not worry about it and just put in either both the yellow or both the clear. anyone else have any more pics with lights on
Old Sep 24, 2002 | 04:56 PM
pu12en12g's Avatar
Well here is what mine look like clear
http://www.puren12g.com/hyperwhite2.jpg
(NOT euro clear)
and YES I'm not gonna lie, it is gonna be hard as hell to do but don't give up.
In order to be street legal, I wanted to try and do what you are thinking of, and it didn't sound that hard until I rewired my relays for the DRL's (none of the online guides worked).
That's when I realized how the blinkers really are designed to work. So I could have either:
1) SUPER BRIGHT DRL's OR
2 be street legal with that mod u are talking about (which I dunno if anyone has ever done)
but not BOTH at once
Old Sep 25, 2002 | 12:41 PM
Lost's Avatar
Sorry to threadjack here but..
Pu12en12g what did you do to the hood vents in that picture? They look functional and taller than stock.
Old Sep 25, 2002 | 05:42 PM
pu12en12g's Avatar
Lost,
I opened them up to extract heat... It's pretty easy to do, and fully reversible.
Novo
Jun 14, 2016 02:58 AM
PopoFormula
Oct 12, 2015 04:19 PM
HAWG
Sep 25, 2015 11:41 AM
tommalcolm
Sep 11, 2015 03:39 PM
