Clear coat over vinyl?
Can you spray a clear coat over something that you've put the vinyl on without harming the vinyl? Kind of 'locking' it in?
When I do my brake calipers soon, I got some vinyl CAMARO lettering from Brent, and if it helps to protect them, I may throw some clear over them.
Re: Clear coat over vinyl?
I did that to mine, but for some reason mine are falling to ****
I cleaned the calipers really well, 2 or 3 layers of color, lettering, 2 layers of clear.
Now it seems like the paint is like melting off almost. It doesn't get clean, the paint will start to come off if i rub hard, and even the letters will start to come off. I figure it might have something to do with not priming it before paint maybe?? It's high temp paint and clear, the engine block stuff. Dissapointing
Maybe melting off isn't the best way to put it. It's like it comes off as if it is partially dry. I used Duplicolor Engine enamel (500 degree) on top of Duplicolor 1500 degree red. It is happening all over the caliper, not just the letters. I cleaned them for days with brake parts cleaner, not sure which brand.
Bad batch of paint maybe? Sounds like paint with no hardner
CARiD
Sep 30, 2015 05:44 AM
