Camaro wheels on Firebird?
Alright i have a 1995 TA that im wanting to put the 10 spoke Camaro wheels on. Will they fit or am i gonna have to grind our the rear ones? Would this be the same if i put them on my 94 Z28? Anybody?
When I had the '96 WS6 rims from off the Camaro swapped out with the 16" chromies on the T/A they had to grind the inner part of the rim on the ones that came off the T/A slightly to fit over the hub on the Camaro. It wasn't much at all that had to be taken off and it was only on the rear wheels that they had any trouble with.
Originally posted by 95_LT1_6SPD
you will more than likey have to grind the hub out a bit to get them on either car.
Well i got to mounting the wheels yesterday and at least 2 rims will have to have lip shaved off. The front fit fine the rear do not, unless you shim. I used 1 inch half round file and took it only took me about 20 minute to do 2 wheels. I did then take a grinding stone and clean it up a bit so it was smooth but they came out great with no issues.
Originally posted by Ace_437
I put a set of new Trans Am take-off wheels on my 93 Z a year or so ago and didn't grind anything off. Seems like they bolted up fine and I haven't had any problems yet.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Nov 30, 2014 08:41 AM
Ask showen04 about his experience!
