Camaro/Firebird interior interchangability
Old Oct 23, 2007 | 04:27 PM
jeff_is_sexy's Avatar
Ok, I know that you can't mix and match anything besides the center consoles. But say I got an entire interior from a 2002 T/A, will it all bolt up to my 94' Z?
I heard that it basically is, except you have to change the gauge plug-ins.
Old Oct 23, 2007 | 04:34 PM
White96Z28's Avatar
There are quite a few people who have done an entire interior swap. I have Pontiac door panels in mine, and kept the Camaro dash, but it can be done. Expect to do some modification to get everything right though.
Old Oct 23, 2007 | 06:31 PM
Got any pics of those doors?
Old Oct 24, 2007 | 12:05 AM
94Z28WP's Avatar
Everything bolts right up except the door panels and the gauge cluster plug like you said. The mounting points for the T/A door panels are different. So you'd have to make new mounting points. Also, the plug and wiring for the power mirrors are different. You'd need the plug off the T/A for it to work. You'd also have to wire it. You'll need the T/A gauge cluster plug and have to remove the wiring from your 94 plug and place it into the corresponding spots on the T/A plug. I did a 2000 Z28 dash swap and T/A interior swap and it's not that difficult. Just a little time consuming.
Old Oct 24, 2007 | 06:35 AM
Do you have to swap the plug if you just go to a 98-2002 Z28 dash? I heard that when you swap the plug and change the dash to the T/A, the gas and tach don't work correctly and it can't be fixed.
Old Oct 24, 2007 | 10:45 AM
94Z28WP's Avatar
Sorry, forgot to mention that I used a 95 T/A gauge cluster in my 2000 Z28 dash. You could use a gauge cluster from a 93-97 T/A or one from a 97 Z28. They will all fit. Anything older than 97 will have the digital odometer and some of the gauges won't work like you said. I couldn't find 97 gauges on ebay so I ended up with one from a 95 T/A. If you use the 97 Z28 gauges, you'll still need to change the plug.
Old Oct 27, 2007 | 05:20 PM
So, I suppose I can just use my existing 94 Camaro cluster with whatever I use, whether it's a 97-up Camaro or a T/A?
Also, will my existing door panels look good/fit with the newer dash? If they work I'll just keep my door panels and gauge cluster and change to a 97 T/A everything else.
Thanks for all this help, by the way.
Old Oct 27, 2007 | 05:22 PM
Executioner2k5's Avatar
no the cluster changed in the Camaros for 97+ you would have to use the T/A Cluster or the 97+ Camaro cluster the newer clusters are shaped different
Old Oct 27, 2007 | 05:27 PM
So basically I'll have to just use a 97-up dash and a 93-96 cluster or else it will be a pain in the butt.
Old Oct 27, 2007 | 05:29 PM
no you will need the 93-96 dash to use yer custer 97+ clusters were shaped different then the older style so if you want 97+ interior or the T/A interior you would have to change the cluster
nosliw
Mar 9, 2016 04:56 PM
Henson071
Dec 30, 2015 09:55 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
scottcba1
Sep 8, 2015 09:52 AM
