Best / Safest way to clean LT1 Engine Bay?
Old Jun 26, 2006 | 05:11 AM
kizzle's Avatar
What is the most efficient, best looking, and safest way to clean the engine bay for an LT1?
Thanks.
Old Jun 26, 2006 | 08:08 AM
Sgt. Spuds's Avatar
Re: Best / Safest way to clean LT1 Engine Bay?
Simple green, soapy water, rags, and a bout 3 hours.
Old Jun 26, 2006 | 06:53 PM
Z28Vert19's Avatar
SAFEST???? PULL THE MOTOR!!!!! lol
Old Jun 26, 2006 | 07:23 PM
GT KILLER's Avatar
Originally Posted by Taintedz28
wrap the opti in a bag
You don't have to do that. Just don't spray any water in the bay. Use rags and wipe things down.
Old Jun 26, 2006 | 07:56 PM
Honda Hunter's Avatar
Ive been told you can use a water hose in the bay, just dont aim it at the electricals. The safe bet would be some simple green, WD40, and elbow greese. I have a Dynaspark and they tell us to spray it with a pressure washer. Cant wait to test it out. Mostlikly wont but my engine bay needs a good spraying.
Old Jun 26, 2006 | 09:18 PM
69z-28's Avatar
i agree with spuds. a good grease remover and cleaner with rags will do the trick
Old Jun 26, 2006 | 10:22 PM
merim123's Avatar
I did mine with engine cold. I used fully concentrated simple green and sprayed everything. Let it soak for a bit(maybe less than 5 min) then I used a water hose with no attachment and let everything wash off with very little water pressure, you'll get the feel for it. I then did not start the car, I let it sit overnight or maybe two days before I started it again. This was about three years ago and I haven't had any problems. Getting ready to do it again to prep for pulling the motor.
Old Jun 27, 2006 | 05:41 AM
kizzle's Avatar
Thanks for the replies guys. Very helpful information.
Old Jun 28, 2006 | 07:04 AM
96 TA's Avatar
Well, im getting ready to do this again to my car, ill pull the Alt. and MAF, plug any holes I don't want water getting into and put a bag around the Opti. Then ill take a 80/20 simple green mix with water and spray everything down. let sit only for a minute or two and then pressure wash everything off. I say pressure wash but really you don't want to get the hose closer then 2ft away from anything. I use the pressure washer just to cover a large area at one time. Makes it go quick.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
formula218
Dec 2, 2014 04:27 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
