Anyone use these headlights?
Old Apr 2, 2011 | 04:16 AM
camarofan21's Avatar
http://astore.amazon.com/camaroz28com/images/B001FBMA7O
In the product description it says they are fog lights, are they or are they lowbeams ? Anyone use them on their car? Was there a change in the head/fog lights from '94 to '95...I bought the sylvania silver star bubls and was going to do the bulb replacement with my headlights, but if these would work, would be brighter, and are truly "plug and play" like it says, I may go with them...Just looking for some info.
Old Apr 2, 2011 | 06:39 AM
Re: Anyone use these headlights?
Update:
Found a couple variations of these bulbs
http://astore.amazon.com/camaroz28com/images/B003LEHDTI
Anyone have experience with the xenon bulbs? I am not looking for anything super bright, but want to go better than my stockers....Also, anyone ever have a problem with legality? Don't know if a 6000k or 8500k as my low beams may be too bright for TX...
Old Apr 2, 2011 | 07:32 AM
JakeRobb's Avatar
Super Moderator
The first one is a fog light -- it says it's an 880 right on it. Unfortunately, you need an 885 for a '93-97.
The second one just says it's a low beam, and doesn't specify the bulb type. It might be correct for a '98-02, which uses the 9006 bulb (which looks a lot like the one pictured), but a 93-97 requires the H4351 sealed beam light, which looks completely different.
Next time you're posting links to Amazon, link to the item page and not directly to the image. It might let us be more helpful.
Old Apr 2, 2011 | 08:24 AM
JBarnaby1987's Avatar
actually I just replaced two low beams on my 96 z28 and you use 9006 for those also.. there is a sticky post on how to change just the bulbs on a 93-97 camaro.. was very helpful and mine work great
Old Apr 2, 2011 | 02:50 PM
Yep, that was the sticky that I was planning to use to swap the bulbs out because I am tired of replacing the whole lamp every time and i want something brighter...And the silver star 9006s that I bought were $50 at AutoZone, so I will definitely take those back and take a higher light output for less $$
Thanks for the help
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
