Anyone add a shacker hood to a 4th gen?
Old Nov 16, 2006 | 08:11 PM
Mikes 1994 z28's Avatar
Curious... post pics
Old Nov 16, 2006 | 10:15 PM
shock6906's Avatar
Someone had a shaker hood on a 4th gen T/A or Firebird. It was on Ebay, I don't know if anybody has the pictures of it. I don't think you'll see it on a camaro though, just my guess.
Old Nov 17, 2006 | 01:46 PM
94_PatriotRed_Z's Avatar
A guy from my local club has one on his LS1 TA
here is his pics
Old Nov 17, 2006 | 01:48 PM
MistaCamawo's Avatar
I dunno about that look...
Old Nov 17, 2006 | 02:23 PM
Brangeta's Avatar
That looks kinda cool. I would absolutely HATE to see one on a '93-'97 Camaro though. That would look like horsecrap.
Old Nov 17, 2006 | 02:37 PM
Grims's Avatar
I'm not very old school. What is the function of a shaker hood?
Old Nov 17, 2006 | 02:55 PM
LT1 POWR's Avatar
Well on my sisters Mach 1, and im sure most shaker hoods are the same, there is a hole in the hood big enough for a ram air scoop that is mounted to the motor so when you rev it up, the scoop shakes with the motor, makeing it a shaker.
Looks good on old school muscle cars but i personally dont think it would flow with 4th gen f-body's.
Here is a pic of her car. Mines faster btw.
Old Nov 17, 2006 | 04:31 PM
Bud M's Avatar
Its cool if its functional, otherwise no. Doesn't make any sense on a 4th gen.
Old Nov 20, 2006 | 11:55 PM
Heatmaker's Avatar
Advanced Member
here is his pics
That doesn't look bad at all... with the strip on there it blends in nicely.
Old Nov 21, 2006 | 08:16 AM
They originated with the early (1970-1/2) Trans Am's.... the air intake/filter was bolted directly to the carb, and a rear facing scoop stuck up through the hood. So when the engine shook, the intake shook in the hood.
In theory, the rear facing opening in the shaker scoop is in the high pressure area at the base of the windshield (same reason for a "cowl" type hood), and boosts HP. There's a flapper door in the scoop opening that opens with a solenoid at high engine loads.
http://www.highperformancepontiac.co...r_hood_scoops/
Old Nov 21, 2006 | 08:55 AM
Grims's Avatar
So, how could you even setup a functional shaker intake on a fuel injected car?
Old Nov 21, 2006 | 04:31 PM
It would take a lot of ducting, sort of like a 4th Gen LT1 SS setup. Instead of the SS hood, you would have a hood with a hole in it, and the shaker scoop sitting on the airbox. It probably wouldn't be very efficient, suffering from the same issues the SS ducting suffers from.... I'd say its for "looks".
A couple years ago, someone did a "retro" 4th Gen T/A with a shaker hood and a rear spoiler similar to the one from the 70 T/A..... it looked pretty good, in white with blue stripes, like the original.
Old Nov 21, 2006 | 04:56 PM
Brangeta's Avatar
GM did that for SEMA or something. It was the partner to the Sunoco concept Camaro.
Old Nov 21, 2006 | 07:32 PM
Heatmaker's Avatar
Advanced Member
Should of made that a production model... as usual the cool things end up concepts.
Old Nov 21, 2006 | 09:04 PM
2000GTP's Avatar
here is his pics
That is awesome.
