adding a power antenna
is it easy to do this? do i just need to get both pugs (male/female) from a T/A along wit the antenna etc would i jus need to splice into the power for the radio and add the ground to the body?
Are you adding it to a Camaro? Yes all you'll need is the plug from a Bird. The antenna will come with a plug on it. I just cut the plug off and installed some quick connect plugs you can get at the local autoparts store. You have to hook up 3 wires.
1. ground
2. power from Radio
3. Wire thats hot all the time.
1. ground
2. power from Radio
To the 97+ Camaro owners with power antennas you may want to do this mod.
http://web.camaross.com/forums/showt...t=antenna+kill
I did it and love it. Now i can keep my antenna down 99% of the time. Please read both of my posts because i had to make a correction to my original post.
The aftermarket radio should have a wire for the Antenna. If the radio was installed correctly the stock wiring should be intact so just splice it into the stock antenna wire.
its installed correctly i jus dont have that stupid Monsson Amp in the back i pulled it out an spliced my speakers wires together at the end where the plug is for the Amp and they worked lol wasnt by my choice
F'n1996Z28SS
Aug 23, 2023 11:19 PM
