AC knob bulbs???
Old Sep 4, 2003 | 03:07 PM
  #16
L44's Avatar
L44
Originally posted by chasmanz28
ok thanks ill buy 2 then, what are you saying about dimming the leds that i cant or they will blow, that would suck, i need to know all this stuff becasue i might want to dimm them and it would be a pita to take everything apart again
Resistors simply just limit the current to the item at hand (in this case the LED) if you use a resistor too large the LED will look dimmed out and not as bright, try hooking a LED to a 9v battery without a resistor an watch what happens you will see a bright flash an the inside turns brownish black because the current wasnt limited and you blew the LED out
Old Sep 4, 2003 | 03:13 PM
  #17
chasmanz28's Avatar
ok i understand i thought you were talking about useing the dimmer switch on the panel itself, i will use 1 resistor per led, thanks bro for all the info
Old Sep 4, 2003 | 03:32 PM
  #18
L44's Avatar
L44
np, you cant really use the dimmer on these, they will dim slightly but the next notch on the **** down will most likely just turn the LEDs off completely they arent like a conventional bulb hope that all helps
Old Sep 4, 2003 | 08:28 PM
  #19
chasmanz28's Avatar
hey bigkernel44 on the resistors will 1/4 watt work or do i have to buy the 1/2 watt
Old Sep 4, 2003 | 09:26 PM
  #20
AW/whiteZ-28's Avatar
The bulb size is 37 and you can find led replacements that will push right into the stock plug (no modification) on www.ebaymotors.com just do a search for the bulb size.
-Archie
Old Sep 4, 2003 | 09:29 PM
  #21
chasmanz28's Avatar
-Archie
are you serious? they have bulbs that size in blue, i was told they dont have them in color
Old Sep 4, 2003 | 09:33 PM
  #22
They are leds and yea they come in blue and other colors here's a link
Old Sep 4, 2003 | 09:35 PM
  #23
L44's Avatar
L44
# 37/74 size bulbs did not fit mine, and yes use the 1/2 watt chaz
Old Sep 4, 2003 | 09:36 PM
  #24
chasmanz28's Avatar
thanks bro that saves me alot of time, ill just buy these babies in blue and pop them in, no wiring needed
Old Sep 4, 2003 | 09:38 PM
  #25
chasmanz28's Avatar
and i was getting my hopes high, what year car you have bigkernel44, where the bulbs to big or small for you
Old Sep 4, 2003 | 09:39 PM
  #26
L44's Avatar
L44
too large =/ i believe the 37's will for 97+ though i have a late model 96
Old Sep 4, 2003 | 09:42 PM
  #27
chasmanz28's Avatar
yeah im doing this on my 96 to so im in the same boat your in then
Old Sep 4, 2003 | 09:43 PM
  #28
Just a thought but you could always trim the base of the led (it is plastic) that way you can make the square peg fit the round hole
Old Sep 4, 2003 | 09:44 PM
  #29
chasmanz28's Avatar
is that what you did to make them fit? what year car you have
Old Sep 15, 2003 | 04:09 AM
  #30
pu12en12g's Avatar
From the diagram... those sure look ALOT like #74 bulbs behind there.
Kernel: did you try actual #74 bulbs and they do not fit ? ?
themex2002
Sep 2, 2015 03:47 PM
4586
Aug 24, 2015 11:04 PM
mattstrike
Mar 11, 2015 07:33 PM
