98 fog bulbs in a 95?
i was wondering if a fog lamp bulb from a 98 would work in a 95. they look the same but one has a 90 degree bend. i think it will still fit but what about the differences in wattage?
If anything the '98 bulb would probably be lower in wattage. Go to www.Sylvania.com and lookup the replacement bulb for each vehicle, and then go to www.donsbulbs.com to find the wattage for each of them. (Your '95 will be a 885 - the '98 will be a 894 - just wanted you to have those links in case your ever in question again).
Originally posted by CLEAR
the 894 is different wattage. will that matter? i mean i want the brightest possible bulb without melting anything.
Aug 17, 2015 09:50 AM
