95 lt1 dashpad
Old May 7, 2006 | 08:29 PM
greenz2895's Avatar
Exclamation 95 lt1 dashpad
i was not shore were to put this but i got a new dashpad because mine is cracked real bad and i want to put the new one in.im just not shore how to do did.help
Old May 8, 2006 | 06:17 AM
97BLOWNTA's Avatar
Re: 95 lt1 dashpad
which part are you talking about? the hard plastic piece that goes to the right up to the windshield or the soft piece that is forward part of the dash that is soft?
Old May 8, 2006 | 04:33 PM
greenz2895's Avatar
Re: 95 lt1 dashpad
ite the hard piece that goes to the winshield.the one with the defrost in it
Old May 8, 2006 | 05:56 PM
94Z28WP's Avatar
Re: 95 lt1 dashpad
-Remove the a-pillars
-Lift pad off the dash
Should be obvious looking at the bottom of the new one... The dash pad is held down at the rear(near the windshield) by 4 or so velcro type fasteners and also one fastener at the point just in front of the defrost vent... Just lift up on it like it's velcroed down.
Old May 9, 2006 | 05:33 AM
97BLOWNTA's Avatar
Re: 95 lt1 dashpad
As 94z28wp said, infront by the windshield there are velcro type connections, towards the interior of the car I do believe there are three(or so) pressure type clips that go down into the dash frame. Just look at the new one for these clips or posts and then go to the one in the car and pry up where these are and then it shouls slide out pretty easy. if you have an alrm light on the dash, you will have to disconnect the wire.
pretty easy, but take your time so you don't scratch or damage the new one or other parts as you remove and install.
Old May 9, 2006 | 05:38 AM
greenz2895's Avatar
Re: 95 lt1 dashpad
thanks guys if i know it was that easy i would have done it a lone time ago
Old May 9, 2006 | 05:40 AM
97BLOWNTA's Avatar
Re: 95 lt1 dashpad
not a problem
oldschool
Feb 9, 2016 09:21 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
