74-78 to 70 conversion
Old Apr 14, 2009 | 06:50 PM
ayers1967's Avatar
I'm planning on converting a 74-78 camaro to look like a 70. Any one on here ever done this? The front will be easy but the rear is going to take some doing. I have seen a t/a that was done before and look sweet.
Old Apr 14, 2009 | 07:32 PM
TechCam97's Avatar
75+ has a different rear window.
1970-1973 Rear:
1974 Rear:
1975-1977 Rear:
1978-1981 Rear:
A 74 model would be your best bet, but even then it'll take some work to make the rear right.
Old Apr 14, 2009 | 08:25 PM
ayers1967's Avatar
Yes it does . But it can be converted .I will be using 70 rear 1/4 panels and tail panel
Old Apr 14, 2009 | 10:37 PM
TechCam97's Avatar
Well good luck with the rear window, I hope it works out for you!
Old Apr 15, 2009 | 08:03 AM
ayers1967's Avatar
It can be done I found some pictures of the t/a that was done .If I can figure out how to post the pictures I will.
Old Apr 15, 2009 | 09:55 AM
6SpdLT1Z's Avatar
[*img]http://urltotheimage.jpg[*/img] Then remove the *
Old Apr 16, 2009 | 09:16 AM
ayers1967's Avatar
picture of conversion
Old Apr 16, 2009 | 12:07 PM
TechCam97's Avatar
Would you be doing the work yourself or paying someone to do it for you? Because body work like that doesn't come cheap.
Old Apr 16, 2009 | 12:09 PM
TechCam97's Avatar
P.S. - I'm not trying to discourage you or anything, just wondering if you thought of all the costs involved with getting this done. That's a lot of welding and paint prep work. I'd check all the costs involved (including the cost of a donor car, unless you have one already) versus just finding a 70-73 body.
Old Apr 16, 2009 | 01:03 PM
ayers1967's Avatar
I do all my own work .Name:  CIMG0575.jpg
Old Apr 16, 2009 | 01:37 PM
TechCam97's Avatar
Sweet, looks like you should have it all under control. Post pics of the process while you're doing it, it's not something you see done all the time!
Old Apr 17, 2009 | 06:50 AM
ayers1967's Avatar
I will do that . I'm doing it because in my area people want 2500.00 for a total pile for junk if its 70 to 73 camaro. You can get 74 to 78 that runs and drives for around 1500.00.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
Henson071
Sep 18, 2015 04:01 PM
tdigger9899
Sep 7, 2015 10:56 AM
RallyRed701/2
Jul 27, 2015 02:55 PM
