4th gen trim advice
4th gen trim advice
the paint on my car is far from great (dents,dings,scratches) but the trim is terrible. it's splotchy black and natural colored. where could i get some new trim and decent paint to match the color or should i go black? my car's a stock color (purple) and i've NEVER seen one of the same color, its kinda wierd, not the gt reddish purple, i've never even seen a gm car the same color. its a coupe so the roof's not black, the whole cars purple, would black look odd, wish i had some pics to post.
Do you mean the rubber is all turning gray? Like the weatherstripping and all that? You can spray silicone lubricant on it and wipe it off with a paper towel and it helps a little. Tirefoam will make a huge mess but make it really black and greasy which could help, but you'll probably need to replace it eventually.
Your car should be Dark Purple Metallic. The Firebird color "might" technically be Cyclamen Metallic. I don't know Firebirds barely at all.
Those are all the same color, even though that last one doesn't look like it is.
thats the color. i mean the body molding along the door, and quarters, i think its to prevent the common height of door dings. i know what you mean tho, the weatherstrippings in good shape. these things were purple at some point. now they are grey, black, purplish. i dunno if all camaros even had them, i kno limited about camaros, lol
if you're a camaro enthusiast, i might as well ask you, once they put the lt1 in a car, the standard tranny was ALWAYS a 6 spd correct? i know the 3800 series was a 5 spd, my friend tried to tell me his 93 donor was a stock lt1 with a 5 spd, i told him, i doubt it
as for body molding, if it comes off clean i'm down to leave it off. goo-b-gone and paint dont mix so gota do my research on what to use to get glue off
carguyshu
Jan 22, 2017 11:19 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
