4th gen Firebird gauge overlay install? easy/hard?
Old Jul 27, 2005 | 10:48 AM
JeffsWorld's Avatar
How hard is it to intall a gauge overlay in the 4th gen Firebird? Before I begin taking apart the dash(and related) I want to see if it is much of an ordeal as I have heard it can be with the Camaro. It looks as though if I remove the cluster bezel from behind the steering wheel (surrounding the gauges) I just need to pop the clear plastic cover off? or do I need to disassemble other parts of the dash to get to that point? Is it worth it? Opinions? Suggestions? TIA -Jeff
Old Jul 27, 2005 | 12:38 PM
gt_biker13's Avatar
Re: 4th gen Firebird gauge overlay install? easy/hard?
Its pretty easy, it just takes a little while taking apart the dash. This should help you http://www.bfranker.badz28.com/fbody/dash.html
Old Jul 27, 2005 | 12:57 PM
JeffsWorld's Avatar
Thanks for the link, I'll check it out.
I was under the impression that the Firebird install may differ from the Camaro install though, but it's worth the read...
Old Jul 27, 2005 | 06:44 PM
madhatter's Avatar
The Pontiac is much easier as all that needs to come out is the bezel around the cluster. Then it is pretty much self explanatory.
Richardan15
May 30, 2015 08:36 AM
cmdeshon
Dec 27, 2014 10:06 AM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
