18 x 9.5 rims won't rub, right?
18 x 9.5 rims won't rub in the front...right? I'm thinking of Y2ks. I know they'll be fine in the back...but I'm just curious about the under full steer...
-Mike
-Mike
Rims don't rub... .tires rub. Whether the tires will rub depends on the correct offset of the wheels, and the width of the tire. For a 9.5" wheel, you are going to be looking at offsets in the 48-56mm range. Put a 275/35-18 tire on that wheel, and it is going to sit in the wheel well pretty much the same way as a stock WS6 or SS 275/40-17 sits. And they don't rub.
I'm just glad to know the TIRES won't rub.
Thanks for the info.
