18 inch rim help
18 inch rim help
i have a 1994 camaro..stock height. i was wondering what do i have to do to make them fit right? do i have to hammer anytyhing? a friend is running 285 35s and he had to hammer the inner fender...i was wondering wher he is referring to? does he mean the lip ? any pics or explainations appreciated.
Originally posted by Green G0blin
the wheels im looking at are 18 X 9.5
does that help? i thought i didnt have to hammer anything with this size, am i correct?
and what size tires recommended? 285/35/18?
245/45/18s?
245/45/18s?
245 is WAY to skinny
The 245/40's and the 275/40's will work but, if you want to keep the stock rolling diameter, 275/35's is the way to go instead of 40's. Just wondering, why do you want to run such a narrow tire in front? 275's fit with no problems/modifications at all.
245/40-18 is kind of narrow, but it is the correct outside diameter, comparable to the stock tires. But you want a 275/35- or 285/35-18 in the back, to avoid mismatching the outside diameter, and throwing your speedometer and odometer off by 4%. The larger diameter also has the same effect as going to lower numerical rear gears, and increases HP loss due to the larger inertial loads.
Sometimes a "good deal" isn't as good as it seems.
well to be honest. i am running 275/40/17s with 373 gears at the moment. and well my speedo is off at this time anyways..which isnt much of a thing i can do. since i have a 3.4 camaro.
so i should go with 275/35s all the way around correct? i think i will just save up some more money
