17x9" wheel. 5.5" back spacing, will it work on a 4th gen camaro?
Old Mar 7, 2003 | 10:54 PM
sc93's Avatar
I am looking at these wheels, and the info given is:
Rear Spacing: 5.5''
Bolt Circle: 5 x 4.75''
Will these fit correctly on a 93 Camaro Z28? How far will they stick out??
Old Mar 7, 2003 | 11:34 PM
TA25th's Avatar
No they won't work.
On the front they would stick out about 1/2"
On the back they would barely be even with the outside fender edge, and might even stick out a tiny bit on the back.
Sorry,
Shawn
Old Mar 8, 2003 | 09:53 AM
sc93's Avatar
damnit,
I really like the Cragar S/S style And they're only $209 each for 17x9's at Jegs
Old Mar 8, 2003 | 09:55 AM
sc93's Avatar
and when you say 1/2 inch in the front.... do you mean 1/2" farther than where the stock wheel goes out to? or 1/2" farther than the outermost part of the fender?
Old Mar 8, 2003 | 10:26 AM
sc93's Avatar
oooh I found these too... they are very nice:
http://www.jdwheels.com/images/212%20transam.jpg
But what size on these would work? Eagle lists in the 17"
17x8 polished, +27mm offset, 5.5" backspace
and
17x9.5, +19mm offset, 6" backspace
would either of those work?
Old Mar 8, 2003 | 10:40 AM
TA25th's Avatar
I mean 1/2" farther than the outermost part of the fender. They would literally stick outside your fenderwell.
And the 17x9.5" ones would be exactly the same. Sorry, but neither one will fit.
Shawn
Old Mar 8, 2003 | 11:18 AM
sc93's Avatar
Ok,
but according to centerline wheels, they make a 17x8" Rebel wheel specifically for 93+ camaro and firebirds. It has 5.5" of backspacing...
http://www.centerlinewheels.com/w_catalog/rebel.html
and here is the wheel on a 4th gen camaro
http://www.centerlinewheels.com/gallery/Gallery42.jpg
so it seems to me like the 8" wide wheel with 5.5" of backspace will work. But not the 9.5" eagles
Old Mar 8, 2003 | 06:15 PM
whiteheartbeat's Avatar
check out my site,i have centerline wheels with
18X8 5.5" backspacing in the front and
18X9.5 7" backspacing in the rear ,the car is lowered 1.5"-2"
they fit just fine!!!!!
whiteheartbeat
Centerline 18x8,18x9.5 wheels,255/35/18,285/35/18 Dunlop tires, Arizona Speed & Marine cold air,mass air sensor,March pulleys,Borla cat back,Hypertech programmer,Mac springs,KYB adjustable shocks,BMR stb,clear corners,clear headlight covers,
Old Mar 8, 2003 | 06:18 PM
I forget to mention that centerline,you can special order they do make the 9.5" wide wheels with a 7" backspacing!!! Thats how i got mine!!
whiteheartbeat
Old Mar 9, 2003 | 05:19 AM
TA25th's Avatar
Yeah, the 17x8 polished, +27mm offset, 5.5" backspace will fit just fine on all four corners of your car.
Shawn
Old Mar 9, 2003 | 09:21 AM
sc93's Avatar
Thanks alot guys,
That narrows my choices down
-Shawn
ChrisFrez
Dec 21, 2014 09:47 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
ChrisFrez
Dec 7, 2014 06:01 PM
