10.5" or 11" wheel questions
Old 04-11-2003, 11:52 AM
twells's Avatar
Question 10.5" or 11" wheel questions
i have my wheel selection narrow down to 3 different wheels. i have to decide between SS/Zr1 wheels, z06 wheels, or y2k thin spokes for my camaro. ok i don't know if this will play a factor in wheel choosing or not, but i would like to put the biggest wheel/tire combo on the back that i can. here is the kicker though....... i don't want the wheel to stick out any farther in the back than the factory wheel would. i would like to keep as much tread under the wheel well as possible. i know that this might require some extra fender work, but that is ok, as long as it is not like tubbing my car or anything like that. i just wanna know what would be necessary to run some big-o-tires out back. would a 10.5" rim be easier to run out back without the wheel sticking out? i can't emphasize enough that i don't want the wheel to stick out any further than stock. i know that people say a 17x11 will fit fine with the proper offset, but every picture that i look at, i still see that the wheel sticks out farther. i don't know what needs to be done, so i was hoping someone could tell me what i need to do.
thanks
thomas
twells is offline
Old 04-11-2003, 01:41 PM
naaz90's Avatar
The 50mm offset zr1 will fit flush with the top of the fender. With the way our Zs are shaped some tire will stick out at the bottom, though. I have a nice pic of someones 315/35-17, PM me if you want me to send it.
naaz90 is offline
Old 04-11-2003, 03:49 PM
stik6shift98's Avatar
i have the 11 inch wheels but have a differnt offset so that they stick out further.....but i would go with the 11s and get the 50mm offset and then they shouldnt stick out
stik6shift98 is offline
BandDirector Blk98ZM6
02-20-2015 07:42 AM
Airplanedoc
02-01-2015 07:14 PM
30thZ4C
Wheels and Tires
01-29-2015 06:03 PM
ChrisFrez
11-30-2014 08:41 AM
redzed
09-04-2002 06:22 PM
Quick Reply: 10.5" or 11" wheel questions
