Why not 10W-40?
Originally posted by FastZinTennessee
GUMP-
What kind of oil pressure do you get with that?
GUMP-
You must be wanting to rebuild your motor bad.
For one that's way way thin and you only running 3.5 quarts?
I can say one thing....good luck and I hope your just real smart.
This is a drag race only thing. It makes quite a big difference in ET.
I only run a factory pump and restrict all of the center drain backs in the lifter valley. As far as oil pressure goes, I really don't think that it is that important for the short period that I am at WOT. You would be really surprised at how good the bearings look when I tear the motors down at the end of the season.
Daren
Daren
Daren- I'm guessing you pull about 40 PSI off the line and close to zero through the traps in top gear?
I used to keep taking oil out of my motors at the track until I started to lose serious oil pressure at the top end. I wouldn't let it get to zero or anywhere near it, but back then I was not familiar with synthetic oils and their "magical" properties. I was just running parts store oil. It could get me a solid tenth, maybe a smidge more on a car only running 13s and shifting at 5500. On a faster, higher winding engine the benefits are probably magnified.
However, it should be noted that this is DRAGSTRIP ONLY kinda stuff. Driven on the street like this the motor would become a paperweight very quickly.
dodge69874
Feb 11, 2011 06:59 PM
CALL911
Sep 10, 2006 11:33 AM
