Who's right?
Old Mar 19, 2006 | 11:03 PM
  #16
1racerdude's Avatar
Re: Who's right?
Originally Posted by n20ta2
My first engine built 12 years ago was lubed with engine oil liberally and the rings didnt seat properly and had to be torn down for a new set.every engine since then has been built wiping the bores with a light machine oil wiped sparingly on the bores, never had a problem since with a good 20 plus engines under my belt.I have heard of the product sstrokerace uses and it also works nicely from what I hear.
These were moly rings?
Old Mar 19, 2006 | 11:19 PM
  #17
SStrokerAce's Avatar
Re: Who's right?
LR, this is the procedure and stuff I use on gapless tops as well. 14-20 Ra, 140-200 Rz on the finsh.
Bret
Old Mar 19, 2006 | 11:25 PM
  #18
1racerdude's Avatar
Re: Who's right?
Bret
Thanks man,
Is that working 100% for ya or are there glitches or ya just have to make damn sure it's right?
Old Mar 20, 2006 | 08:46 AM
  #19
speedyjr's Avatar
Re: Who's right?
When you are using that molly quick seal, what procedure do you use to brake in the motor? I don't have a dyno at my disposal right now, but I want this new motor to be broken in as best as possible. Thanks guys.
Old Mar 20, 2006 | 09:51 AM
  #20
thesoundandthefury's Avatar
Re: Who's right?
Is anybody breaking in their motors with a starter instead of under fire?
Old Mar 20, 2006 | 11:44 AM
  #21
Re: Who's right?
You want to warm the motor up, check to make sure everything is tight (rockers, head bolts/studs) and then start beating on it. That will break it in perfectly.
LR that's worked perfect for me, even rougher I don't think is a problem. The rougher the better most times, less chance for glazing the bores over.
Bret
Old Mar 20, 2006 | 01:28 PM
  #22
1racerdude's Avatar
Re: Who's right?
Bret
Old Mar 20, 2006 | 01:34 PM
  #23
n20ta2's Avatar
Re: Who's right?
yep they were moly
Old Mar 20, 2006 | 01:43 PM
  #24
1racerdude's Avatar
Re: Who's right?
yep they were moly
Molly don't like oil for break in.
Old Mar 20, 2006 | 09:29 PM
  #25
n20ta2's Avatar
Re: Who's right?
Yeah tell me about it,It was my first engine though and i had no clue.I have learned just a bit since then
Old Mar 20, 2006 | 09:38 PM
  #26
1racerdude's Avatar
Re: Who's right?
When ya learn that way ya don't forget.
Old Mar 26, 2006 | 01:44 AM
  #27
racer7088's Avatar
Thumbs up Re: Who's right?
I have heard of this stuff but never seen it used ever to my knowledge?
I have never had a ring not seal up when honed correctly and with good quality rings and a torque plate etc.
Why is this stuff supposedly needed? If the bore is round and the rings are round they are sealed before start up.
Old lower quality iron rings need a peaked finish and some time to seat but that was because the bores and rings both left a lot to be desired.
What does this stuff do? I HAVE heard about it but when I ask people about it no one has ever used it 99 per cent of the time.
