while on the subject of valve springs.. Seat pressure
Old Oct 4, 2007 | 09:09 PM
Brady's Avatar
we've had some problems with the car breaking up at higher rpm. If I test seat pressure and it's where it should be, are the springs OK, or is there more to it than that?
We use the PSI 1248's FWIW, installed at 2.100"
the cam is 308/318 advertised and 276/286 @ .050 with .782/765 lift.
Valves are 2.30/1.88 stainless on conventional heads
The springs probably have nearly 100 passes on them. Everyone says "change them, it's time" but how do I know
Old Oct 4, 2007 | 09:12 PM
mdacton's Avatar
check seat and check them open. I never checked mine and ended up with 40# of seat pressure
Old Oct 4, 2007 | 09:39 PM
MachinistOne's Avatar
Check the pressures and report back.
.200 long valves?
Old Oct 4, 2007 | 09:45 PM
Brady's Avatar
.200 long valves?
I don't have the means to check open pressure. I can check seat pressure though. I don't have any idea on valve length. I'm sure it's whatever comes in a set of BB2Xtra w/CNC.
Old Oct 5, 2007 | 09:47 AM
1racerdude's Avatar
Brady.
Did this just start?
Ya may need more spring than recommended,
260-270 seat and 8-900 open would be my guess maybe more with the blower.
Take one spring off and get it checked at your lift.
Old Oct 5, 2007 | 10:42 AM
Brady's Avatar
1-E 260# I 320#
2-E 280# I 300#
3-E 250# I 270#
4-E 280# I 300#
5-E 250# I 270#
6-E 250# I 280#
7-E 300# I 260#
8-E 280# I 270#
It just started, but we're have fuel delivery issues too- waterman pump was dying... I'll have the heads off in another hour or so to see if we melted anything...
Isky's webpage says the springs should be 375# on the seat and 1045# open... FWIW.
(waits for captain obvious to suggest changing the springs..)
Old Oct 5, 2007 | 11:03 AM
1racerdude's Avatar
I would check them before replacing a high dollar spring set.
May be the pump as lean/rich will cause that too. If its lean it will usually just lay down,rich will cause the miss/studder. Now this depends on the degree of rich/lean also.
Old Oct 7, 2007 | 01:31 AM
marshall93z's Avatar
Wow, those pressures are all over the place!
And DAMN that car sounds wicked idling!
Old Oct 7, 2007 | 01:39 AM
I would be checking installed heights to make sure they're the same - 50lbs is a huge amount of variance.
What's the Isky Toolroom spring #?
I would be looking at ignition issues once you get the springs set up.
Old Oct 7, 2007 | 10:17 AM
Brady's Avatar
The seat pressures were all close to the same and over 300# when I checked them in April.
New springs are on the way, and when I took cap/rotor off- it's apparent there are some "issues" there as well...
The springs are actually PSI-1247 all installed right around 2.060
thanks!
Old Oct 9, 2007 | 08:58 AM
1racerdude's Avatar
Keep digging,no telling what you will find on that high class thing.
Old Oct 11, 2007 | 10:27 AM
SStrokerAce's Avatar
Ok
Rule #1 installed height is MORE important than installed pressure. Lot of old hats are going to disagree with me on that from a lack of understanding spring dynamics... that's ok, controlling the spring is all a product of how they are used.
Who is the cam from?
Int lobe is 308 @ .020"? 276 @ .050" ???? @ .200" and .460" lobe lift? (1.7:1 Rockers?)
Exh lobes is 318 @ .020"? 286 @ .050" ??? @ .200" and .450" lobe lift?
I'm hoping this is no more than 196 @ .200" int and 201 @ .200" exh
I'm guessing you are using 145g+ and 135g+ valves here...
The PSI 1247 Tripple 1.660" Diameter spring is NOT light by any means you are easily talking a 175-200g spring!
The problems I can see here....
1. You need roughly .100" shim under each spring from where they are now
2. You need gods pushrod in there with rouchly 1700lbs at the pushrod/lifter. At minimum I would run a .125" wall 3/8ths and even then with a 8"+ BBC PR I would rather run a 7/16"+
3. I think you have the wrong springs here, I'd look more at PSI 1242 in @ 2.000", 1571 @ 2.000" or a 1573 @ 1.980", that's 250-275lbs seated.... 675-750open. I'd also throw .015-.020" more shim at the exhaust springs as well. I'd go with the 1500 series stuff myself so I didn't have to run into this problem again anytime soon.
Bret
Old Oct 11, 2007 | 12:02 PM
1racerdude's Avatar
Bret,
I will be running that much spring pressure N/A with a 2.08 SS valve.
Closing against the BIG boost he has, is that enough? Just curious.
You loose more by not enough spring than too much.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Roadie
Feb 16, 2015 10:34 AM
Snoman73
Nov 17, 2014 07:22 PM
Timberwolf
Jul 30, 2002 08:31 PM
