Where can the LT1/LT4 intakes be improved if any?
Old Sep 18, 2003 | 02:53 AM
  #106
PurePonyPounder's Avatar
What ever came about from that one individual who was going to manufacture an LT1 out of thermoplastic material. I know the material and process is an expensive one but has anyone tried making this into reality.
Johnny
Old Sep 19, 2003 | 01:39 PM
  #107
MadMaxz28's Avatar
i got a reply back from someone over at more performance.. he said they gained 100hp over the ls6 intake on there 427ci monster. said it gained from about 4500 on up and they spun the 427 to 7000rpm. im wondering how much hp/tq over 4500 it would give me after i fully port my afr's (310cfm@600 or about) also awesome low/mid lift #, solid roller etc.. FAST or DFI. i think a good sheetmetal setup could net 50rwhp very easy. so 500rwhp N/A shouldnt be out of the question.. jim lab made more then that because of his raised runner heads. (flow like ls6 heads). now the problem $2000 for 50rwhp
Old Sep 20, 2003 | 05:47 AM
  #108
NJLT1SS's Avatar
I will be doing some serious porting to my LT4 intake for my 396 currently being built, being topped off with AFR comp port 210CC LT4's. I will have some welding done behind the injector bosses, and maybe around them too, depending on how crazy I decide to get with it. I will try to get some pics up when its done.
Nick
Old Sep 21, 2003 | 11:54 AM
  #109
DaveZLT1's Avatar
So who can raise the roof on the intake?
Old Sep 21, 2003 | 02:53 PM
  #110
SStrokerAce's Avatar
Dave,
Getting the roof raised on a LT1/4 intake is not hard if you have a good aluminum welder. I usually machine a patch for a aluminum plate and have that welded to the intake. Then the rest is port work and matching the intake to the heads. Then when it's done just powercoating it again.
You can also check with Jordan about this, I know he does intake porting.
MadMaxx,
Yeah Mores intake is not cheap, but that puppy made that power with more than just that intake. The $2900 headers they have helped too.
I think these guys just matched them though
http://www.ls1tech.com/threads/showf...o=31&fpart=all
The new LSX Comp/FAST intake should be a good alternative
Bret
Old Sep 29, 2003 | 09:38 AM
  #111
Did anyone by chance get to read the new "Corvette Fever" magazine, anyway they have an article on Wilson Manifolds based out of Ft. Lauderdale, FloridaWilson Manifolds that's currently producing LS1 manifolds called LSX manifolds with significant changes to the inside tract. Maybe someone in the local area can spearhead a call or visit with them directly to see the feasibility on producing a polymer intake for our LT1's. Thanks
Johnny
Old Sep 29, 2003 | 10:30 AM
  #112
Actually Wilson manifolds designed the LSX intake and then FAST which is a division of Comp is selling it.
Polymer intakes for a LT1 probably will not fly since they cost so much to make. This is a big investment by FAST to make this intake.
Here are some pics of the intake
http://www.thunderracing.com/images/LSX_big.jpg
http://www.thunderracing.com/images/lsxintake2.jpg
http://www.thunderracing.com/images/lsxintake1.jpg
http://www.thunderracing.com/images/lsxintake3.jpg
In that last one you see the Wilson Burst panells for N2O
Bret
Old Sep 29, 2003 | 12:00 PM
  #113
kmook's Avatar
Advanced Tech Moderator
Johnny
Hey Johnny, Im close to them and went down to get a tour of the place about 2 months ago. Nice looking stuff but $$$. As far as a polymer intake for LT1s, wouldnt ya think they would need a large demand to make those?
Old Sep 29, 2003 | 05:01 PM
  #114
WS6 TA's Avatar
You could easily design one that would work for both an LT1 and a traditional SBC, or use the same basic pattern with different inside bolt locations and adding the cooling passage on the front of the SBC one, so you really could do very little design work and end up with a manifold that would cover 3 very popular engines (pre ’87 SBC, late SBC and LT1)
Old Oct 1, 2003 | 07:23 AM
  #115
Anyone call or paid a vist to Wilson Manifolds............... By the way WS6 TA that was a good idea to float to Wilson. There would be a nice number of individuals who could use the intake besides on just LT1(4).
Johnny
Old Oct 3, 2003 | 01:04 AM
  #116
Let me clarify first that I emailed Wilson Manifold directly and received a response stating that they worked with Comp Cams/Fast Fuel Injection on the design for the LSX intake manifold. Has anyone inquired with Comp Cams on whether its possible to work on a LT1 intake project. I know they produced a thermoplastic intake for 5.0 crowd a couple of years ago. Well if anyone can call them that would be greatly appreciated.
Johnny
Old Oct 3, 2003 | 02:14 AM
  #117
Next time I talk to them I can ask.
The problem is there are so many SBC intakes I don't know if they would.
There has to be packaging constraints on this thing too. You would have to change the head bolt patterns rather than the intake since you can weld it up and start over on a standard SBC to LT1 conversion.
BTW that FAST/COMP intake (which yes Wilson helped design) is sell for $795. That's pretty dam good for a polymer intake manifold. They made it because the need for one was there, as far as packaging, and performance are concerned. IMHO converting a Stealth Ram to work on a LT1 is a better idea, than making a polymer intake. Putting some TBC on it would help that out even more.
Bret
Old Oct 3, 2003 | 10:54 PM
  #118
StanIROCZ's Avatar
Originally posted by JordonMusser
ok, finally have some pics of this up:
on the left, a standard ported LT4 intake.
on the right, a welded intake. the cross section is MUCH more consistant, and although the roof line is still not perfect, it is MUCH closer to what you would get from a Hogan, etc. not a stupid "ski jump" like the stocker
http://www.musserracing.com/heads/intake/raceport2.jpg
Jordon, could you please link some pics of the welding that you did behind the injector. Just trying to get an idea of what you did.
Old Oct 4, 2003 | 02:28 PM
  #119
96 WS6's Avatar
Anybody know how well a TBC or a thermal dispersant coating will work on a LT1 intake??? I've been considering TechLine coatings... anybody?
May 1, 2015 01:14 PM
carl.froehlich
Mar 13, 2015 12:38 AM
CARiD
Jan 27, 2015 06:27 AM
RichJ
Sep 26, 2002 09:43 AM
