What tools do I need to do basic porting?
Old Oct 18, 2005 | 08:53 PM
stubbs's Avatar
I am porting out a set of SLP runners. Another member linked these pics on what to port using his job as an example. Now what do I need to do this? Is a Dremmel strong enough? Any advice would be appreciated since I have Zero experience doing this kind of work.
Here are the pics
http://www.ws6transam.org/car/tpirunner2.jpg
http://www.ws6transam.org/car/tpirunner1.jpg
Old Oct 18, 2005 | 10:03 PM
aggiez28's Avatar
Re: What tools do I need to do basic porting?
a Dremmel can work, you could even use a drill (althought its deff not the best thing to use)
you will need carbide bits and some cartridge rolls. if you do a search you will probably find alot of info
this may get moved out of this section too, kinda iffy if it falls into advanced tech
brook
Old Oct 18, 2005 | 11:28 PM
boosted-lt1's Avatar
I might suggest a basic porting kit. Summit sells one.
http://store.summitracing.com/defaul....asp&x=42&y=15
I remember this from a year or so back, it may help.
http://www.sa-motorsports.com/diyport.shtm
-Scott.
Old Oct 23, 2005 | 09:48 PM
dochall22's Avatar
when porting heads, how "exact" do you have to do it? do you have to be really precise on how even it is?
Old Oct 30, 2005 | 11:30 AM
RedThunder1994's Avatar
my best advice is extensive research, find some pictures of how to, and if that doesnt give u any confidence in a few days or so dont touch them, givem to a pro because my buddy tried it and didnt listen to me on how he needed to becareful with the runners and actually slowed his car down because he screwed the flow of the heads up, best bet is just a gasket match for now and let a pro go further
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
ChrisFrez
Feb 22, 2015 08:47 AM
