What are the do's and don'ts when attempting valvespring replacements
Old Dec 20, 2002 | 07:20 AM
  #16
rasilverbird's Avatar
Originally posted by LTOne4Fun
This loss is before the 3.90s went in, I havent raced the car since
*cough cough..driver error..cough cough*
Old Dec 20, 2002 | 08:45 AM
  #17
Highlander's Avatar
With a pin clip.. I clipped the purple wire going from the big bunch of cables on the passanger side...and ground... That is the starter cable... I used a manual starter to crank the engine (no ignition) so lifter would charge with oil... then I adjust to zero lash, just when the rocker has no play with the pushrod... then 1/4 turn and that is it...
But a good practice is to turn the engine because lifters will charge and the height will change... has worked wonderfully for me
Old Dec 20, 2002 | 02:13 PM
  #18
big dave's Avatar
I didn't realize there was reason behind turning the motor over by hand. I just bumped the starter til the valve started to open. Does this mean I should go back and do them all over again?
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Dec 1, 2016 05:37 PM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
