What cooling system mods are necessary to run Evans NPG+?
Old Feb 19, 2003 | 11:50 PM
LTOne4Fun's Avatar
Any way I can get by with the stock radiator?
Old Feb 20, 2003 | 06:53 PM
anaik's Avatar
I run NPG and I have a stock system except for the 160 stat and 7lb cap. No problems.
Old Feb 20, 2003 | 08:22 PM
LTOne4Fun's Avatar
What kind of cam/compression gas are you running, and why a 7 lb cap?
Old Feb 20, 2003 | 08:54 PM
anaik's Avatar
I have a 215/224/112 cam, stock compression. The 7lb cap is what Evans told me to use.
Old Feb 20, 2003 | 08:56 PM
Dr.Mudge's Avatar
If the boiling point of the liquid is high, there is no need to put the cooling system under as much pressure, which only serves to raise the boiling point. I believe Chuck said some run a neutral cap, no poundage at all, but feel free to check the thread for that info, could have been someone else.
Old Feb 20, 2003 | 09:09 PM
anaik's Avatar
Type in Evans NPG and Quickss in the search function for the Advanced forum. There is an informative thread on it.
LTOne4Fun's Avatar
I thoguth Chuck was big on not using Evans unless you do some cooling system mods, and only if your very familiar with the stuff? is there a difference between NPG and NPG+
Noenav
Mar 1, 2019 07:38 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
