what about this 383 set up
Old Jun 22, 2004 | 03:41 PM
1994TransAm's Avatar
got a good price from cnc motorsports
"ESP" Balanced Street strip Rotating Assemblies are the perfect choice for the street peformance, towing, yet economically prices. Balanced Kit features:
New STD/STD Cast Steel Crankshaft
New 5140 Steel "SIR" Lightweight Connecting Rods
SRP Forged pistons, piston pins and oil rail support when required
Piston Rings: File Fit Piston Rings
File fit rings include plasma ductile iron top ring, reverse twist 2nd ring, standard or low tension oil ring and oil rail support when required
Clevite 77 Rod and Main Bearings
Internally Balanced
Kit # Stroke Cub. In. Rod Piston Type Dish/Dome CR w/58cc CR w/64cc CR w/76cc Piston Rings
B13052
3.750 383 6.000 Inv Dome -16cc 10.4 9.8 8.7
6 inch rods i hear will help with wear?
any used these sir rods?
Old Jun 22, 2004 | 04:21 PM
WS Sick's Avatar
Ive used the eagle SIR rods a few times in street performance, limited drag use and they held up just fine, I used them in my 93 (6 inch ) in a 355 and they held up fine for 7 years to my mean driving style (mean to the car that is). I recently rebuilt the motor and the rods looked new. I'm usung 5.7 SIR eagles in my 383 in my 97 right now.
Old Jun 22, 2004 | 08:52 PM
got_hp?'s Avatar
did i miss the "advanced" part?
Old Jun 22, 2004 | 10:36 PM
amean94ta's Avatar
content removed
Old Jun 22, 2004 | 10:43 PM
amean94ta's Avatar
btw so you dont buy and find out later you have to have the weight knocked off the flywheel and have the assembly nuetral balenced most likley about $200-$450 depends on the shop that does it.
Edited By Moderator: Do not try to sell things on this site if you are not a supporting advertisor. If you have 'one' of something to sell, post it in the for sale forum. Thank you.
cheapchevy
Apr 8, 2015 08:48 PM
kaoticcamaross
Feb 17, 2015 03:13 PM
MadMav
Feb 6, 2015 11:02 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
