weird oil pressure problem
Old Aug 8, 2005 | 06:37 PM
  #16
JordonMusser's Avatar
West South Central Moderator / Special Guest
Re: weird oil pressure problem
windage tray requires different mounting hardware, so if you used ARP bolts or such, you are kinda SOL. I would put a canton pan on it, since you gotta drop the pan anyway.
Unless moroso, or somebody makes another easier alternative. But the canton pans work well, have built in scraper/screen
Old Aug 9, 2005 | 02:33 PM
  #17
TheNovaMan's Avatar
The only alternative would be a Canton or Stef's screen type windage tray that you bolt or weld onto the pan. But that's really more work than just getting a pan with it on there already, unless you already have a good pan and a welder and want to save a few bux.
Old Aug 9, 2005 | 05:13 PM
  #18
RCF925's Avatar
You can use the stock windage tray with ARP bolts, You just have to get the right ones, I'm using the windage tray with HV pump with ARP bolts and stock pan on my 385. Here's a pic http://www.cardomain.com/ride/624351/1
Old Aug 14, 2005 | 07:44 AM
  #19
pearlpurple's Avatar
I know for sure on my 93LT1 that the pickup was too close to the pan and it did the excact same thing!!
Old Aug 21, 2005 | 08:40 PM
  #20
killer305's Avatar
dont know if you have concidered this but have you checked the crankshaft endplay, on some manual cars the constant depressing of the clutch can cause some play in the crank and is apparent if oil pressure drops under WOT
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
