Voltage problems...drops under wot
Old Nov 17, 2003 | 09:33 PM
sleeperz28's Avatar
I tried this in LT1 tech will no help so ill give it a shot here.
I have always had this problem with the car. It drives around on 14.0 volts then under a wot run its at about 12.5 @6500rpm. This is one of the reasons my injectors are getting hit so hard. My alternator is a 200amp so that cant be an issue. I have an adjustable regulator on it, sent it in for testing no problems there. I re-wired all my main power wires with 1 gauge, so nothing is too small...Any ideas this seems to be a common problem with the LT1 cars. Anyone that can data log around here sees the same results as I, with LT1's. Even a few that can see the gauge drop under wot.
Old Nov 17, 2003 | 09:35 PM
Belt slipping?
Old Nov 18, 2003 | 02:07 PM
sleeperz28's Avatar
Originally posted by Injuneer
Belt slipping?
Not showing any signs, and no auditable noise on the dyno.
Old Nov 18, 2003 | 11:19 PM
OneFlyn95z28's Avatar
I would LOVE to see an answer to this one as I have had this problem since the car was new
PopoFormula
Oct 12, 2015 04:19 PM
SergheiS
Sep 29, 2015 08:56 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
Aug 7, 2015 01:26 PM
