Viper's variable valve timing w/cam in block engine
Old Mar 21, 2007 | 08:07 PM
  #16
Z Power's Avatar
Originally Posted by LiENUS
VTEC just advances or retards the cam.
This will explain vtec better than i could type it out
http://www.autozine.org/technical_sc...vvt_2.htm#VTEC
Old Mar 21, 2007 | 10:49 PM
  #17
thetoy's Avatar
http://www.hotrocker.com/ What about this?
Old Mar 21, 2007 | 11:33 PM
  #18
LiENUS's Avatar
Thats a relatively new vtec I believe I'm not sure thats even in the us yet
Old Mar 21, 2007 | 11:52 PM
  #19
chuck's Avatar
Actually Honda's VTEC uses two cam profiles, and a funky hydraulic actuator to choose the lobe. There is an actual switch over from the small lobes to the big which is audible. That goes back to at least the '99 Civic Si, and I think the Preludes had them before then.
EDIT: I have been hoping solenoid technology would advance to a point that constantly variable everything as far as valve timing is concerned for years now.
Old Mar 21, 2007 | 11:56 PM
  #20
LiENUS's Avatar
Then I am way behind on VTEC because the VTEC I read about was just advancing or retarding the cam.
Old Mar 22, 2007 | 12:02 AM
  #21
RussStang's Avatar
VTEC has never just advanced or retarded the cam. There have always been two cam profiles with the VTEC system, dating back to the early 90s when it first debuted with in the NSX. At a specific rpm an solenoid locks the rockers that follow the smaller profile together with a rocker that follows the more radical lobe together using oil pressure I believe, and the valves are opened and shut by the more radical profile. The change is an audible difference. It is a pretty trick system.
Honda has the VTEC listed as meaning Variable Valve Timing and Electronic Lift Control. Yeah, I know, the acronym is horrible, but that is taken straight from a brochure about the system when it was first introduced.
Old Mar 22, 2007 | 08:41 AM
  #22
91Z-28's Avatar
Does anyone know how the VVT on the L92 works? I've seen next to nothing on it still. I think I'll search ls1tech and see if they have anything for me to cross post here.
Old Mar 22, 2007 | 08:54 AM
  #23
91Z-28's Avatar
http://gm.wieck.com/forms/gm/previewpage?026545
Looks like it is an advance/retard system.
Old Mar 22, 2007 | 01:53 PM
  #24
LiENUS's Avatar
Perhaps thats why I was confused about VTEC I appologize, I need to stay more current on my reading apparently.
Old Mar 27, 2007 | 05:52 PM
  #25
Soccerbum21's Avatar
vtec on honda/acura started back with the NSX. it was the first VTEC motor. the vtec that we're all familiar with comes on a variety of 4 cyl engines (b series, H series, D series, etc). even single cam motors can be vtec. my beater civic is a 97, 1.6L SOHC VTEC automatic with 210k miles on it.
two intake valves per cylinder, but three cam lobes. (the DOHC models have the same thing on the exhaust side, but the SOHC models only have 1 exhaust valve) an oil pressure solenoid that locks the three follower/rocker arms together to ride on the middle cam lobe which has a higher lift/duration than the "low lobe"
the newest versions of vtec, like found on the RSX and basically any K-series motor, is the same 3 lobe for 2 valve design, but it incorporates an advance and retard feature to increase mpg, and decrease the "vtec hit", making a smoother transition from the low lift to the high lift lobes
my old roommate showed hotrocker to me, and i have always wondered if anyone had it on their car. it seems like a good idea, but i would imagine it being a complete PITA to tune it.
AdsoYo
May 2, 2018 03:21 AM
oldschool
Feb 9, 2016 09:21 PM
Jazsun
Dec 29, 2014 12:14 PM
Jul 4, 2005 05:00 PM
routesixtysixer
Jun 23, 2002 02:29 PM
